Vibe struts vs matrix struts
Posted: Wed May 28, 2014 8:52 am
by phillydoe22
Are these struts interchangeable? Can I order matrix struts to directly fit on the vibe??? Help!
Re: Vibe struts vs matrix struts
Posted: Wed May 28, 2014 1:40 pm
by lannvouivre
Yes. 03-08 FWD Matrix and Vibe struts are the same, ditto for the AWD models for that year. For the second generation models, I'm not really sure which trim levels have independent rear suspension. As long as it's the same trim level and you only match FWD to FWD and AWD to AWD on the second gens, you're fine.
Posted: Sat May 31, 2014 10:34 am
by vibenvy
lannvouivre wrote:For the second generation models, I'm not really sure which trim levels have independent rear suspension. As long as it's the same trim level and you only match FWD to FWD and AWD to AWD on the second gens, you're fine.
Yep. The 2009-2010 Vibe AWD and GT (Matrix AWD and XRS) have Independent Rear Suspension, while the 1.8L & 2.4L Bases do not, so they will have different rear struts depending on which model it is. The front struts should all be the same.
