should I change the spark plugs?
Posted: Thu May 15, 2014 11:37 am
by jeff_j1701
Hey all!
I have an '07 Vibe with just over 200K on it.
The owner's manual says to replace the spark plugs at 200,000 but I haven't really had any issues with them. They are the original spark plugs.
Would there be a reason why I should change them?
Thanks!
Re: should I change the spark plugs?
Posted: Thu May 15, 2014 12:35 pm
by Raven
When I changed mine on my '06 at 160K they looked brand new and the gap was perfect on all 4. If it's running well, I would keep on going with them.
Posted: Thu May 15, 2014 12:52 pm
by Caretaker
+1 to that ^^^
Posted: Thu May 15, 2014 7:08 pm
by Salsa Guy
Yes change them. It'll cost $20 and 15 minutes of time.
Posted: Thu May 15, 2014 7:13 pm
by Chiadog
2X change them, unless you want to wait for the ceramic on one of them to fall off into the combustion chamber!
Posted: Fri May 16, 2014 9:55 am
by SeattleJeremy
I agree with Chiadog and Salsa, change them.
They are suppose to be changed every 100k miles. That's great they've lasted as long as they have, but they will eventually fail, causing more headaches then it's worth.
They will cost you about $9 each for the right ones. Use the NGK BKR7EIX. This is the stock plug, and is the best plug for this engine.
http://www.monkeywrenchracing.com/produ ... cts_id=581" onclick="window.open(this.href);return false;
Posted: Fri May 16, 2014 1:14 pm
by Caretaker
Jeremy/others: what would be the best plug (iridium) for the second gen Vibe (corolla engine)?? The link you provided was for 2.4 liter (camry engine) only. How about the 1.8?
Posted: Sat May 17, 2014 11:25 am
by SeattleJeremy
Caretaker wrote:Jeremy/others: what would be the best plug (iridium) for the second gen Vibe (corolla engine)?? The link you provided was for 2.4 liter (camry engine) only. How about the 1.8?
jeff_j1701 has a 2007 Vibe. The links says the following.
Fits:
2005+ Lotus Elise, Exige, 2-eleven with 2ZZ or 1ZZ engine
2000-05 Celica, MR2 All
2003-08 Matrix/Corolla/Vibe All
2009+ Matrix/Corolla/Vibe 2.4L
Posted: Sat May 17, 2014 6:54 pm
by Mark
This one: http://shop.advanceautoparts.com/p/ngk- ... spark+plug" onclick="window.open(this.href);return false;
Might as well change or at least clean the PCV while you're there, just make sure you get the right one.
Posted: Sat May 17, 2014 8:44 pm
by triz
Change them. It's cheap maintenance at the very least. The plugs should be chAnged every 100k. You'll get better spark, mAybe even a bit of mileage.
What would Jesus do?
Posted: Sun May 18, 2014 8:23 am
by Raven
triz wrote: What would Jesus do?
He'd drive a Tesla! :shock:
Posted: Sun May 18, 2014 12:04 pm
by Caretaker
Mark, that isn't the right plug for what I asked for, plus the PCV valve isn't anywhere near the plugs. You have to take off the intake manifold to get to it and then have to replace the intake manifold gasket. NGK wasn't even listed in the Advanced Auto search for the 1.8 liter SECOND generation Vibe.
Posted: Sun May 18, 2014 2:40 pm
by lannvouivre
NGK ILKAR7B11
Denso SC20HR11 or 3444
I googled 2ZR-FE NGK.
Posted: Tue May 20, 2014 5:25 pm
by Mark
Caretaker wrote:Mark, that isn't the right plug for what I asked for, plus the PCV valve isn't anywhere near the plugs. You have to take off the intake manifold to get to it and then have to replace the intake manifold gasket. NGK wasn't even listed in the Advanced Auto search for the 1.8 liter SECOND generation Vibe.
Yeah, sorry. I always forget how much different the 2nd Gen 1.8L is.
Posted: Wed Jul 16, 2014 6:12 am
by MarkM66
The owners manual states to change them at 200k miles, and not before????
Posted: Sun Jul 20, 2014 4:10 pm
by bobho
So they changed the Spark Mileage it would seem. I'm one of those old timers who remember changing plugs every 10,000 miles. Plus changing the points and condensor.
I agree that they should be changed
Posted: Sun Jul 20, 2014 4:21 pm
by gtv237
Besides even if its running good, it might not be 'running good'. It could have weak spark causing it to run rich which can foul up the inside of the engine and reduce efficiency. I would replace them with none other than the original ones toyota put in from the factory. I mean they got you to 200k, didn't they?
Posted: Tue Jul 22, 2014 6:07 pm
by mbz321
I replaced mine a few weeks ago (111,000miles on my Vibe) and the car seems to be driving a little better, but maybe that is just a placebo. The plugs I removed didn't look too terrible. Anyway, for less than $25 (NGK's. Ordered them online from AdvanceAuto with a coupon code and picked In-Store Pick Up), there wasn't any harm in changing them, IMO.
Posted: Wed Jul 23, 2014 10:17 am
by circuitsmith
MarkM66 wrote:The owners manual states to change them at 200k miles, and not before????
200k kilometers. Op from Canada, hey?
