Monroe Quick Struts 03 GT
Posted: Tue May 13, 2014 8:50 am
by tabaker0214
Not sure if this has been posted but I have done alot of searching through the old posts and have not come up with anything on the Monroe Quick struts for the rear set-up.
I had been looking to replace my struts for a while now and have had good success with Monroe's Quick Struts in the past and wanted them again for the Vibe. I found the fronts which can be had now through Advanced Auto Parts for $225 Shipped after $50 off with Code TRT30. I know the fronts are available at many places but thats the cheapest I had found.
The Rear struts were more challenging. I looked everywhere for them and searched this board and the thinkg that kept coming back was they did not exist anywhere. Monroe DOES have the quick struts listed for the rears but NO ONE has them. Then I remeber rockauto.com, I just picked up some fog lights from them so I checked for the rear quick struts and there they were. $240 shipped for BOTH rear Monroe Quick Struts for the rear.
I will let you guys know how it goes when I get them all delivered and installed, hoping this weekend or the beggining of next week. I'm excited since everything on the car is OE and has not been replaced.
These new struts will go great with my new tires and rims that I had just gotten last week.
Re: Monroe Quick Struts 03 GT
Posted: Tue May 13, 2014 4:27 pm
by ParknVibe
Correct me if I am wrong, but there are no struts on the rear suspension....but only shocks. So you don't have Quick setup with a spring.
Here is the Monroe Quick strut for the rear wheels of the 2003 Vibe....171373L (left)
http://www.monroe.com/en-US/catalog/e-Catalog" onclick="window.open(this.href);return false;
So you are half right.
Posted: Tue May 13, 2014 4:59 pm
by ParknVibe
ParknVibe wrote:Correct me if I am wrong, but there are no struts on the rear suspension....but only shocks. So you don't have Quick setup with a spring.
After reviewing my big service manual for the 2009 Vibe, They call it a shock absorber. However, it is setup like a front strut... But in order to remove it you must support the lower control arm with a arm jack. Then you can take it off. The spring stays in place....
I hope you have a manual to help you to do this.
Posted: Wed May 14, 2014 12:14 pm
by tabaker0214
Monroe Rear Quick Struts (Or whatever you want to call them) has arrived, This will be my weekend project, just hoping I get the fronts in by this weekend to do them all in one shot.
Posted: Wed May 14, 2014 5:09 pm
by kumquat
Definitely struts on the rear of the Vibe, both 03 and 09. The spring and shock are a combined unit, and must be removed from the vehicle that way. To replace just the shock, you must use a strut compressor to remove the spring.
Posted: Wed May 14, 2014 5:40 pm
by danimal86
Take lots of pictures. I need to replace my struts, and i may go this route
Posted: Wed May 14, 2014 8:35 pm
by Salsa Guy
I just put a set of Monroe quick struts on the 03 Vibe GT and "shocks". Interesting that they list them as struts but look like shocks to me with the coil over design. The fronts I had one problem when checking the torque on the last top nut and broke the bolt at 25 ft/lbs. The spec is 29. Not happy with that. I either need to purchase a new top or replace the whole strut.
Posted: Wed May 14, 2014 10:43 pm
by lannvouivre
Salsa Guy wrote:I just put a set of Monroe quick struts on the 03 Vibe GT and "shocks". Interesting that they list them as struts but look like shocks to me with the coil over design. The fronts I had one problem when checking the torque on the last top nut and broke the bolt at 25 ft/lbs. The spec is 29. Not happy with that. I either need to purchase a new top or replace the whole strut.
Ohhh, so you're on Facebook now!
I broke a stud on a new rear engine mount with what the Toyota manual listed as factory spec. The GM manual's spec was 20 ft-lb lower. :roll:
Posted: Thu May 15, 2014 4:39 am
by kumquat
That's what a strut is: a shock with integrated coil.
Posted: Thu May 15, 2014 6:33 am
by danimal86
Other than the broken bolt, whats your thoughts on them?
Posted: Thu May 15, 2014 8:59 am
by tabaker0214
So I won't have the front setup until next Tuesday so I guess I will be working on the rears this weekend. I will keep you guys updated on how it goes with them.
Posted: Thu May 15, 2014 5:30 pm
by Salsa Guy
No clunking in the front. The broken bolt was VERY disappointing. I'll order another from Rockauto, swap them, then return under warranty. I'm really p I s s e d over that.
The rears 1 was made in US and South Africa they had 2 different top designs. The US version I did not have the proper "adapter" to check the torque (need to post a PIC).
I had less issues with the rears than the front.
On my way to HCMO in Erie PA. All Vibes are considered Matrixes, all is welcome. Red Roof Erie if you are Hard enough!
Posted: Thu May 22, 2014 11:24 am
by tabaker0214
Ok so the fronts quick struts came in this week and I will be working on them next week since this weekend I have to work on replacing a fuel pump for my brothers 2000 Mustang GT, thats gonna be a fun project.
I did however get the rear Monroe Quick struts in today and here is what the look like installed.
Not too bad, it only took maybe 1 1/2 hour to do both.
The ride with just the rears is Great, no more bottoming out going over bumbs in the rear.
Posted: Sun May 25, 2014 9:18 am
by Salsa Guy
The rears were simple except for doing the Torque on 2 of bolts when the car is off the stands.
Posted: Wed Jun 04, 2014 11:07 am
by ken99287
Did you guys end up having to get your cars aligned after install?
How does the monroe quick strut assemblies compare to stock? I remember when I first got my vibe, it handled like a go-cart with the stock suspension.
What did you guys end up paying for them got the part numbers? There are 2 grades, I believe.
Posted: Wed Jun 04, 2014 12:42 pm
by Salsa Guy
Yes I did an alignment are driving about 2 weeks. I did break a top strut bolt when setting it to 28ft/lbs.
Posted: Fri Jun 06, 2014 7:19 pm
by Salsa Guy
I just got my $90 Rebate debit card back from Monroe today. It took them about a month but basically I replaced my rear Struts for free!
Posted: Thu Jun 11, 2015 11:49 am
by msmyer
I have 257k on my Vibe and looking at the Monroe Quick Strut? How do you guys like them?
Posted: Thu Aug 20, 2015 7:55 am
by cythraul
msmyer wrote:I have 257k on my Vibe and looking at the Monroe Quick Strut? How do you guys like them?
I hope to have an answer about this question this afternoon. I just drove my '07 to get all four replaced (front was saggy and rear was losing fluid.)
It's a pity I did not take the time to check Rock Auto. Canadian Tires was having a special (50%) on struts only (80$ each) but the Quick Struts are special orders at 320$ each. After arguing they gave me a 25% rebate. Still 410$ over what Rock Auto was selling at regular price.
If they did not already removed the back, I would have bailed out and ordered from RA.
cyth
