Possible fuel pump noise
Posted: Sat Aug 09, 2003 10:51 pm
by shali1
When lifting my foot off the throttle after coasting, my car makes a noise almost like a pidgeon cooing coming from the fuel pump area. putting the foot on the throttle then off duplicates the noise . This happens intermitently. Has anyone encountered this.
Re: Possible fuel pump noise (shali1)
Posted: Sun Aug 10, 2003 2:14 am
Nope, no pigeons in this guy's vibe...
Re: Possible fuel pump noise (silverawd26)
Posted: Sun Aug 10, 2003 10:56 am
by dmitri
do you have a manual or auto?
Posted: Sun Aug 10, 2003 10:22 pm
by shali1
I have a base vibe automatic
Posted: Mon Aug 11, 2003 1:24 am
by LocDog
a couple days ago i noticed a sound comin for the engine when i accelerate to drive away after just starting the car. its like a squeeking, reminds me of a car with old worn belts.... You think its the belts?
Posted: Mon Aug 11, 2003 1:30 am
In a Vibe, the fuel pump is in the gas tank, accessible under the rear seat.
Re: Possible fuel pump noise (joatmon)
Posted: Thu Dec 22, 2005 1:07 pm
by damronjr
Quote, originally posted by joatmon »In a Vibe, the fuel pump is in the gas tank, accessible under the rear seat.Holy dead thread, Batman! JOAT, do you know how to get to it from under the seat? I assume I just have to remove the lower bolts under the rear seat and pull it up. Then what do I expect? Any help would be awesome as this may be a/the source of my dead Vibe problem right now.
Re: Possible fuel pump noise (damronjr)
Posted: Thu Dec 22, 2005 2:53 pm
by Mase
Remove the bolts holding the front of the seats down. Then get something to prop them up otherwise you'll get pissed at how hard they fight back.The pump is under the tin cover dead center between the seats. The cover is usually just taped or puttied down.If you need more room, you'll have to completely remove the rear seats. To access all the bolts, you'll have to first completely remove all of the cargo floor area.
Re: Possible fuel pump noise (Mase)
Posted: Fri Dec 23, 2005 1:14 am
by damronjr
Thanks again, Mase!
Posted: Mon Oct 23, 2006 8:34 am
by kadie233
Quote, originally posted by shali1 »When lifting my foot off the throttle after coasting, my car makes a noise almost like a pidgeon cooing coming from the fuel pump area. putting the foot on the throttle then off duplicates the noise . This happens intermitently. Has anyone encountered this. I have also experienced the pigeon noise. It happens to me nearly every time I drive my car. I have taken my car in three times and they were not able to replicate the noise and they would not ride in the car with me. Sometimes my car also makes this loud whining noise like a seal is barking - it is so loud it frightens pedestrians. Was anybody able to determine the cause of the pigeon noises? Is it the fuel pump? My warranty has expired and I have run out of patience with this car. Any advice would be greatly appreciated.
Re: Possible fuel pump noise (kadie233)
Posted: Wed Jan 10, 2007 2:55 pm
by tcam
Is this pigeon noise like a brief "pop" kind of? I don't remember what pigeons sound like. lol. cuz if it is, then I have this problem too.
