2003 5 speed to 6 speed swap
Posted: Thu May 01, 2014 7:15 am
by ZERO6
Has any one done this?
I have a 6 speed ready to go.
Need to know if its a direct swap???
Re: 2003 5 speed to 6 speed swap
Posted: Thu May 01, 2014 7:22 am
by KITT222
Other people have indeed done it, and as long as it is the C60 6-speed transmission (00-05 Celica GT-S, 03-06 Matrix/Corolla XRS, 03-06 Vibe GT) then it will bolt right up and work with the 5-speed parts. You'll need a new shiftknob, though (for obvious reasons).
Posted: Thu May 01, 2014 7:23 am
by ZERO6
Have you done it?
KITT222 wrote:Other people have indeed done it, and as long as it is the C60 6-speed transmission (00-05 Celica GT-S, 03-06 Matrix/Corolla XRS, 03-06 Vibe GT) then it will bolt right up and work with the 5-speed parts. You'll need a new shiftknob, though (for obvious reasons).
Posted: Thu May 01, 2014 8:24 am
by EricTMah
Only a direct bolt up if the C60 came from a Corolla XRS, Matrix XRS or Vibe GT. The celica one will work, but you'll need to modify it slightly. MWR sells the kit you'll need to make a Celica one work.
I've swapped a 5speed into my Corolla XRS as a temporary fix in the past. It literally bolts right up.
Posted: Thu May 01, 2014 11:09 am
by ZERO6
Yes just verified it is from a GT and is the C60 tranny.
So no issues then, correct?
Just the purchase of the shifter
knob..?
Posted: Thu May 01, 2014 1:52 pm
by KITT222
I have not done it myself (autotragic) but others have. In fact, someone out there swapped from automatic to the C60 6-speed. Anyway, yes, it will bolt right in, and the only thing needing changing will be the shift knob.
Posted: Thu May 01, 2014 3:19 pm
by EricTMah
Are you planning on replacing anything else while it's out?
Clutch and flywheel? If yes. You're going to need to get new flywheel bolts. You shouldn't use the ones you're taking out.
Posted: Thu May 01, 2014 5:59 pm
by Salsa Guy
Awesome....good path...but the MPGs may drop a little.
Posted: Fri May 02, 2014 4:22 am
by ZERO6
If any knows the person that did this, please point them
in my direction..
I have a shop to do the work, but want input on "Do it Yourself".
Pretty much main reason for this thread..
Thanks Matt
Posted: Fri May 02, 2014 8:48 am
by thebarber
ive done it
bolts right up
Posted: Mon Jul 07, 2014 11:15 am
by mntn-biker
I've done the swap also. During the swap, I replaced:
new flywheel (and ARP bolts) http://www.twosrus.com/catalog/product_ ... cts_id=304
new aftermarket clutch
new front struts (since it was apart anyway)
Here's a "How To" thread but unfortunately, the pics are no longer shown:
viewtopic.php?t=17517
Posted: Mon Jul 07, 2014 11:52 am
by sideshowalan
Feels like i drag this link out every few months when this topic comes up.
How-to with pictures, this is a Clutch Job write-up but it shows how to remove/reinstall the trans :
http://wehavescissors.blogspot.com/2009 ... be-or.html
