Struts bar on 09 base...
Posted: Tue Apr 29, 2014 7:28 pm
by metaxa44
Hi,
Is it a good improvement to intall a struts bar on a 09 base 1.8L Vibe ???
Should I do the brear one too???
Is it possible to do it with out removing winshield wiper assy ???
What makes are reccomended???
Where is a good place to get it ???
I am on Ontario so would be nice to know a supplyer up around here...
Thanks..
Re: Struts bar on 09 base...
Posted: Tue Apr 29, 2014 9:22 pm
by KITT222
The upper strut bar does have an affect on handling. The rear lower one does, too, but that one has a little more of an effect. Really, any and all bars will do something. I even have an upper rear strut bar, and holy bananas, does that thing have an affect. But for someone who doesn't want a hardcore feel of the road (hi) I'd stick with the front upper, and rear bar. I can't vouch for the ease-of-install of the front one on the 09/10 models, but I'm sure another member (vibenvy?) will have more advice on that. However, just a guess, you may have to remove the wiper cowl, as it covers the strut towers.
Kijiji might have something, otherwise check Ebay for TRD bars for the 09-14 Matrix/Corolla. Maybe even Matrixowners.com (when it's up) or the Toyota Matrix bookFace page. I know I saw someone with a front upper for the second gen for sale there the other day.
Posted: Wed Apr 30, 2014 4:02 pm
by metaxa44
Thanks KITT..
Posted: Sat May 03, 2014 11:53 am
by Rayven01
I installed the OEM GT strut bar on my base 09 (thanks Vibenvy!) and it made a big difference in lessening body roll on turns. Without it even though the tires were rock solid at speed on turns I had to take it slower or get thrown against the door.
You don't have to remove the wiper assembly but it makes the job a lot easier. Removing the wipers and shroud (simple) took less time than finagling the strut tower bolts with the shroud in the way. It was also a good chance and provided easy access to remove all the leaves and debris that made their way under there (a lot more than I expected).
Posted: Sat May 03, 2014 3:23 pm
by vibenvy
Our 2009 Vibe GTs came with OEM front strut tower braces which were okay, but I highly recommend the
TRD front strut tower brace. I replaced our OEM braces with the TRD ones last summer and the difference is night and day. The OEM brace is 3 separate pieces bolted together and it's really heavy. The TRD one is a solid one-piece aluminum bar that weighs probably half as much as the OEM brace. It really tightened up the front end when turning, going around curves, cornering, etc. And it looks a lot nicer then the OEM brace which I always thought was pretty goofy looking.
I can't say from personal experience (because unfortunately it won't fit the 2009-2010 AWD or GT), but there are a couple members here (
vibedrivermatt &
MaSlade) who have installed the
TRD rear anti-sway bar on their 2nd gen 2.4L Base Vibes and have said it made a huge difference.
vibedrivermatt actually posted how-tos for installing both the
TRD front strut tower brace and the
TRD rear anti-sway bar. I can also vouch that the strut tower brace comes with excellent instructions with pictures and all. I'm sure it's the same for the anti-sway bar.
As Rayven said, it is pretty easy to remove the windshield wipers and all the plastic cowl pieces and it gives you a lot more room to work. I too took advantage and cleaned up under the cowl panels while I had everything apart. There was quite a bit of crud under there
As far as ordering, I highly recommend
TRD Sparks. I'm reasonably sure they will ship to Canada. Their prices are awesome and they have super fast shipping.
Here are a few pictures...
OEM vs. TRD (I removed the TRD badge before installation. It’s held on with double sided tape.)
Posted: Wed May 07, 2014 4:23 am
by metaxa44
Thanks guys...
