How to remove instrument cluster on first gen vibes
Posted: Sun Apr 27, 2014 3:36 pm
by striker1211
I had to put tape over my TPMS light because I only have sensors in my winter wheels so I decided to make a quick video. I hope it helps someone. It really is an easy thing to do and now I don't have to see a blinking orange light.
1. Pull bezel off.
2. Remove one screw at top (plastic should be under metal tang fyi).
3. Push in metal clips at bottom on either side.
4. Unhook two wiring harnesses.
5. Pull it out.
6. There are plastic clips all around the cluster that allow you to remove the clear plastic but you will need a small flathead screwdriver or dental pick to remove them easily.
7. Install is reverse of removal. Cluster sits gently onto metal tabs at bottom and then tighten top screw.
Link:
http://www.youtube.com/watch?v=ndgzkHvAXrw
Re: How to remove instrument cluster on first gen vibes
Posted: Mon May 12, 2014 5:26 am
by Doug14
Good How to! but im curious, have you tried resetting the TPMS in your summers? IIRC the 03-08 vibes dont use sensors in the wheels but rely on part of the ABS system. anyone with more info feel free to chime in.
Posted: Wed Sep 03, 2014 9:09 pm
by striker1211
My car does not have ABS, there are infact sensors in my wheels.
Posted: Thu Sep 04, 2014 4:35 am
by Doug14
That makes sense!
