				Eibach Pro Kit springs
				Posted: Fri Apr 25, 2014 9:14 pm
				by ChuckstrPT
				Anyone have any experience with Eibach Pro Kit springs?  I've got 185k on my stock suspension, and I'm looking into freshening it up.  I really don't want to lower it too much at all, as I see some fairly rough roads, but I'm thinking I'd like to firm it all up a  bit.
     Thanks!
				Re: Eibach Pro Kit springs
				Posted: Sat Apr 26, 2014 1:54 pm
				by KITT222
				I don't have them on my car, but I have heard very good things about them. I think member shaeet has some for sale, or at one time did. You could look for his post, and message him for his opinions.
				Posted: Sun Apr 27, 2014 6:33 pm
				by thebarber
				eibach makes a great spring.  if you have 185k miles on your struts, id get some new ones while you're swapping everything...
the vibe has a ton of clearance...even lowered 1.2", you should have issues.  the progressive rates are very compliant
				Posted: Mon May 05, 2014 7:58 pm
				by ChuckstrPT
				thebarber wrote:eibach makes a great spring.  if you have 185k miles on your struts, id get some new ones while you're swapping everything...
The struts are most definitely shot.  That's what started this conversation.  I have to replace the struts, to do that, I'll have the springs off...so, if I want to replace the springs, now is the time.
				Posted: Tue May 06, 2014 4:24 am
				by kumquat
				Monroe makes a QuickStrut assembly for the '05. It makes the job so much easier it's ridiculous. Goes from 2 hours per side to 30 minutes.
				Posted: Tue May 06, 2014 8:52 am
				by thebarber
				tokico blues...also from microimageonline.com
