Correct engine oil for 2010 1.8L? 5W30 or 5W20?
Posted: Sun Apr 20, 2014 12:35 pm
by SuperVibeMan
Hi Folks,
What are you all using in your vehicles? My owners manual says SAE 5W-30 but the oil filler cap says SAE 5W-20. Which is correct? I've been using the 5W-20 Napa Synthetic but want to know if I should trust the manual or the filler cap? Have any of you faced this same situation? Was the manual printed in error or the wrong cap installed? I appreciate any feedback.
Thanks!
Re: Correct engine oil for 2010 1.8L? 5W30 or 5W20?
Posted: Sun Apr 20, 2014 1:07 pm
by star_deceiver
I used 0w20 for winters and 5w20 for summers for the time I owned my Vibe.
Posted: Sun Apr 20, 2014 2:15 pm
by ab2cmiller
Toyota engine and Toyota Matrix manual specifies 5w20. GM for whatever reason chose to specify 5w30. Bottom line is if Toyota is specifying 5w20 I wouldn't have any problems in putting in 5w20, but put in 5w30 if it makes you feel comfortable.
Posted: Sun Apr 20, 2014 3:38 pm
by kumquat
5W-30 won't hurt it, but you should be using 5W-20 or 0W-20.
The owner's manual is wrong. The GM Service Manual specifically states:
"For temperatures above -20F (-29C), use 5W-20. 5W-20 is best for the vehicle."
Later it states that 0W-20 should be used when temperatures may go below the above.
I believe the owner's manual also specifies the wrong transmission fluid. I think it says DEXRON. These trannies take WS though, which is also specified in the GM shop manual.
Posted: Sun Apr 20, 2014 3:40 pm
by kumquat
Also, check the oil filler cap. Mine says 5W-20.
Posted: Mon Apr 21, 2014 3:35 am
by beemerphile1
Manual was a misprint, use either 5w20 or better yet use 0w20 if you can find it.
Posted: Mon Apr 21, 2014 5:23 pm
by SuperVibeMan
Thanks much for the clarification guys.....I really appreciate it! 5W20 it is!
Posted: Wed Apr 23, 2014 3:44 pm
by vibenvy
Both our 2009 GTs get 5W-20.
Posted: Thu Apr 24, 2014 4:57 am
by triz
Engine Oil
Grade 1......API*[1]
Performance Plus XL 5W-20 Synthetic Motor Oil (XLMQT)
Performance OE 5W20 Synthetic Motor Oil (OEMQT)
All TEMPS......5W-20, 0W-20 [2]
Manual Transmission,C59 (5-SPD)......GL-5
All TEMPS......75W-90 [3]
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 (MTGQT)
Automatic Transmission,MVB......WS [4]
Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATL) (ATLQT)
OE Fuel-Efficient Synthetic Automatic Transmission Fluid (OTLQT)
Fluids
Clutch Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [5]
Brake Fluid......HB
[1] Oil must be formulated to meet GM standard GM6094M.
[2] SAE 5W-20 is preferred.
[3] Synthetic gear oil, GM P/N 12346190 or equivalent.
[4] GM P/N U.S. 88863400, in Canada 88863401
[5] Hydraulic Brake Fluid, DOT 3 P/N 12345347, spec. 9985642
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (EA15K01)
Oil Filter WIX 57064 Oil Filter
Air Filter WIX 49104 Air Filter
Cabin Air Filter WIX 24483 Cabin Air Filter [1]
[1] Not all models may be outfitted with a cabin air filter. Please verify before ordering.
NGK PLUGS AND WIRESETS:
PREMIUMIRIDIUM PLUG ILKAR7B-11
WIRESET WIRESET
WIPER BLADES:
Blade Class Driver Passenger Rear
ExactFit T261 T171 T11A
NeoForm T16260 T16170
Winter T37260 T37170
CHASSIS LUBRICATION:
0 Fittings, 0 Plugs
CAPACITIES:
Engine, with filter..........4.4 quarts [1]
Cooling System, Initial Fill..........5.8 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, MVB Initial Fill..........2.6 quarts
Automatic Transmission, Total Fill
4 speed MVB..........6.9 quarts
Manual Transmission, C59 (5-SPD)..........4 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....27 ft/lbs
Manual Transmission
Fill Plug 29 ft/lbs
Drain Plug 29 ft/lbs
