using Overdrive to slow down
Posted: Thu Apr 10, 2014 7:12 am
by bull77
I have a 06 auto vibe and had a question about using the overdrive button to 'downshift' to lower speeds.
For example - turning off OD to slow the car down without braking or in addition to braking (ie: in traffic, sudden stop, speed at or lower than 60km/hr).
Does it harm the transmission to turn off OD in these scenarios or should it only be used when towing?
Re: using Overdrive to slow down
Posted: Thu Apr 10, 2014 8:29 am
by Nasmfell
OD in mostly set it and forget it. About the only time you may want to turn it off, is going down a steep hill and you don't want to overuse your brakes to slow down/stop. In that instance turning off OD would free up some engine braking to help slow down/stop the car. Besides that, again it is really set it and forget it.
Posted: Thu Apr 10, 2014 2:44 pm
by Rayven01
In exceptional circumstances like you list it's fine and probably good to do. It's not going to hurt your transmission unless you do it constantly. Some people like to downshift early in sport mode on purpose at every stop to save their brakes. In that case it makes no sense. Over the long haul it will cause more transmission wear and brakes are a lot cheaper than transmissions.
Posted: Fri Apr 11, 2014 3:29 am
by beemerphile1
Turning OD off is in essence downshifting one gear. It is fine and is recommended.
Automatic transmissions are great but manually shifting an automatic is perfectly acceptable depending on conditions. Since I tow several trailers I manually select the correct gear many times. No matter how good the computer in a car gets, the computer inside my head is still superior. I choose to select the correct gear for the situation.
I sometimes manually downshift when descending hills or before stopping. I sometimes lock out OD on mountain roads to prevent the constant up/down shifting of a transmission seeking the perfect gear.
Posted: Tue Apr 15, 2014 10:32 am
by bull77
beemerphile1 wrote:Turning OD off is in essence downshifting one gear. It is fine and is recommended.
That's what I thought -- I only turn it off when speeds reach at or below 60k/hr and haven't seen/heard any issues yet. :D
