Handbrake Warning Light not working?
Posted: Sat Apr 05, 2014 12:19 pm
by dannyboy
Hi, not sure if this is the right place for this, first time posting. I have a 2006 Vibe AWD and I've noticed that the handbrake warning light not longer comes on when the brake is applied. I know the light itself works as it appears when I start the car and I know that the handbrake itself is working too. Anyone else have this issue/know possible causes? Other details; about 2 years ago I accidentally left the handbrake on while driving for about 10min before realizing it. In a possibly related note about a month later I had to replace both front discs and rotors.
Any help is much appreciated!
Re: Handbrake Warning Light not working?
Posted: Sat Apr 05, 2014 2:44 pm
by KITT222
Welcome to GenVibe! The switch for the handbrake warning light is on the handbrake lever assembly, accessible by just removing the four 10mm bolts holding the center console in (two in front, in the little tray, two in the center console compartment towards the rear). Since it is so simple to remove the center console you could just pull it out and see if something is wrong with the switch itself.
Hope this helps!
Posted: Sun Apr 06, 2014 5:35 am
by lannvouivre
KITT222 wrote:Welcome to GenVibe! The switch for the handbrake warning light is on the handbrake lever assembly, accessible by just removing the four 10mm bolts holding the center console in (two in front, in the little tray, two in the center console compartment towards the rear). Since it is so simple to remove the center console you could just pull it out and see if something is wrong with the switch itself.
Hope this helps!
It may even be that the connector right in there is simply dirty. Someone on here had to clean old soda off of his.
If you're lucky, you may even find some FREE POCKET CHANGE under there!
Posted: Sun Apr 06, 2014 4:19 pm
by dannyboy
Thanks for the quick replies, I'll take a look when I get a chance and let you know what I find out.
Posted: Wed Apr 30, 2014 7:09 am
by dannyboy
lannvouivre wrote:KITT222 wrote:Welcome to GenVibe! The switch for the handbrake warning light is on the handbrake lever assembly, accessible by just removing the four 10mm bolts holding the center console in (two in front, in the little tray, two in the center console compartment towards the rear). Since it is so simple to remove the center console you could just pull it out and see if something is wrong with the switch itself.
Hope this helps!
This seemed to be the case indeed, I popped the switch open and the contacts were covered in corrosion and dirt. Cleaned them up and cleaned the pin the switch plugs into and everything works perfect now. And I found 35cents! Thanks for the help!
Posted: Wed Apr 30, 2014 7:41 am
by kumquat
Nice. Not often you fix your car and end up with more money than you started with.
