Sold !!!!!!!!!!!!!
Posted: Sun Mar 30, 2014 6:50 pm
Last chance before i start Parting it out !!!!!!!!!!!
03 vibe gt 1.8L 2zz engine and a 6 speed trans . It is running 8psi of boost and was making 254hp to the wheels before i upgraded the turbo and had it retuned it had an ebay t3 now has a t3/t4 turbonetics so its closer to 300hp now with a faster spool . The car has quite a bit of extras over 6k just in parts. It is my daily driver and needs nothing .Vehicle has 182k miles on it, and has the following Modifications ......
Custom Rear mounted Turbo Kit Very easy to work on !
Turbonetics T30e4 turbocharger 50 trim (good for 400+ hp)
AEM fic Pigyyback ecu
550 injectors
MWR Fuel Pump
turbo xs BOV vent type
Oil Scavenging Pump
AEM AFR Gauge
MWR Short Shifter
Auto meter Boost gauge
Other gauges water oil press (not name brand)
Dual row Aluminum Radiator
Dual 10 inch Fans
Polly Mounts for engine & Steering/Sway bars
Progress rear Anti sway bar
Tokico Blue Struts installed 10k miles ago
Suspension Techniques Lowering springs
17x7 ASA wheels custom painted gun metal with Red lip (matches Car)
225 50 17 tires 70% tread left
Front Strut Bar
Planet Audio in dash DVD 80x4
800w amp under pass seat to run speakers
Pioneer 6.5 front components
Kicker 6.5 Sub woofers in rear doors
additional 2'' pioneer speakers on front door (3 way component)
Kenwood powered 5x7 subs under drivers seat
car has one small dent behind the gas door, ( i popped most of it out with a mallet) paint did not chip. also has 1 large scratch on pass doors , ( it was keyed before i purchased it ) other that that the paint is how you would expect with normal wear and scratches
im not apposed to parting it out but id like to see if i can sell it whole first , im in no rush just selling because i just got a new turbo forester awd
550 injectors
MWR Fuel Pump
Oil Scavenging Pump
AEM AFR Gauge
MWR Short Shifter
Dual 10 inch Fans
Front Strut Bar
