very loud tick/knock
Posted: Sat Mar 22, 2014 11:15 am
by sciko67
It started as a tick and got louder and louder. Now it could probably be called a knock. It is coming from the intake side on the engine. Could this be anything fixable, or have I likely bent a valve?
Re: very loud tick/knock
Posted: Sat Mar 22, 2014 2:34 pm
by Raven
More info would be useful. Year, mileage, engine etc.
P.S. It's not a bent valve. It would be misfiring.
Posted: Sun Mar 23, 2014 5:33 am
by sciko67
2003 2wd vibe with 150,000 miles. 1zz motor. It still starts and runs. No check engine light. Power only feels about 1/3 what it is supposed to be. I suspected a bad sparkplug, so I replaced them(coil on plug if that matter). I used NGK platinum. The noise doubled after the replacement. I changed the oil, it was unfortunately very low. Maybe a quart and a half. The oil was silvery. No big metal flakes, but that oil wasn't healthy looking.
Posted: Sun Mar 23, 2014 9:09 am
by Raven
You were down almost to half your oil capacity. You should have saved some of the old oil for analysis.
It's beginning to sound (no pun intended) like a rod bearing is gone. Quite terminal for an engine. You're likely looking at a rebuild or used replacement engine. Used engines for the Vibe are plentiful and quite cheap.
http://car-part.com/index.htm
There are a lot on Ebay as well.
Posted: Sun Mar 23, 2014 9:41 am
by sciko67
I looked up spun rod bearing on YouTube and that is exactly what my car sounds like. How momentous of a project would it be to rebuild the engine?
Posted: Sun Mar 23, 2014 12:13 pm
by Raven
sciko67 wrote:I looked up spun rod bearing on YouTube and that is exactly what my car sounds like. How momentous of a project would it be to rebuild the engine?
Seeing as it was run very low on oil there is probably other internal damage. Unless you have a friend who is a mechanic and owns a garage it will be expensive for parts and deadly for labor. A low mileage used engine is the way to go.
If you don't stray too far from home you could drive it until it dies if you are planning to replace the engine. If there is an engine not too far away it's no problem to put it in the back of the Vibe to bring it to a garage. I picked up a Subaru EJ25 in Connecticut, 17 hour round trip with my '06 Vibe.
Posted: Sun Mar 23, 2014 3:30 pm
by sciko67
What is the difference in price and difficulty between a 1zz replacement and a 2zz swap?
Posted: Mon Mar 24, 2014 3:28 am
by Raven
You didn't say if your Vibe was auto or manual. The GT is manual 6 speed only. A swap would be involved and expensive. You'd need the GT ECU, wiring harness and complete transmission and engine
Posted: Mon Mar 24, 2014 8:07 am
by Salsa Guy
The 2zz swap won't be that bad with the MT. You can put a 03-04 XRS/GT GT ECU in (the 03 has a lower LIFT point). The Harness for the 03-04 1zz vs 2zz is almost identical you may need to add a couple of wires for the LIFT. But if you can find a 03-04 XRS/GT harness that would be the way to go.
Posted: Mon Mar 24, 2014 10:24 am
My 03 base had bad rod bearings and was giving me a knock. I replaced them with a generic bearing set from autozone. Can do it from under the car if you are careful. No pan gasket, just sealant. Cost was about $50 plus an oil change. Car was still running fine when I traded it in on a different 03 about 100K miles later, so I think I'll have to disagree that a worn bearing means the engine is terminal. Might be other damage, but not a sure thing.
I said a "generic" bearing set, because there was a thread here within the past year where apparently Toyota sells slightly different thickness bearing sets, identifiable by a mark stamped on the rod cap.
monkey wrench racing 25-60K 1zz
Posted: Wed Mar 26, 2014 12:50 pm
by sciko67
We bought our vibe last year for under $6000. Automatic, FWD family car. It had 150,000 miles, but it was in great shape. Now that the engine is blown, my options are, fix it cheap and sell it, or fix it right and keep it. As low and silvery as the oil was, I feel this engine is a bag of worms. Not worth the time even if I could fix it. No other decent car is in our price range, and everything else on this car is in great shape, so I think I am confident enough to spend $2000 on a good, low mileage engine, and push it for another 200K miles. Monkey Wrench Racing has one right in that price range. 25-60k miles on it. 2005+ piston design. I believe I could install it myself. Does anyone have advice or insight for me?
Re: monkey wrench racing 25-60K 1zz
Posted: Wed Mar 26, 2014 1:44 pm
by lannvouivre
sciko67 wrote:Does anyone have advice or insight for me?
Just wondering, have you done this kinda thing before? If so, I bet you've got it. These cars are cakewalk easy to work on most of the time.
Posted: Wed Mar 26, 2014 2:54 pm
by Raven
I don't know what part of the country you're in but there's a bunch I looked at in Upstate NY with low mileage in the $1,200 to $1,500 range. There are hundreds listed on this website. Probably one is near you.
25-60 K is a pretty vague and large spread. They will likely middle man it from a wrecker nearby.
Posted: Wed Mar 26, 2014 4:58 pm
by sciko67
In in Indiana. Nothing is listed around here that I trust. I haven't done an engine change before, but I've done almost everything around it. Disconnect Intake, exhaust, everything on the serpentine belt, spark plugs, injectors, transmission, hoses, wires, motor mounts, and I figure it should lift out.
Posted: Thu Mar 27, 2014 9:45 am
by sciko67
There is a company in Ontario, California called Kar King Auto that sells remanufactured 1zz engines with the improved piston design, all new gaskets, piston rings, etc, New oil pump, and new water pump, for $2100 shipped to me in Indiana, I keep the core. I think I've found my best bet.
Posted: Thu Mar 27, 2014 10:27 am
by Raven
That sounds pretty decent. The shipping alone from Cali would be expensive.
Posted: Thu Mar 27, 2014 1:15 pm
by sciko67
What Kar King does to all rebuilt engines:
complete engine disassembly
(pistons, rings, bearings, timing chains, plugs and other parts are discarded)
thermal and or chemical cleaningÂ
(engine block, cylinder heads, cranks, cams)
engine block crack inspectionÂ
(Visual and/or Magnaflux)
crankshaft reconditioningÂ
(Grinding and Micro Polishing)
boring and honing of cylinders
connecting rods are inspected and replaced with new or rebuilt ones as required
block resurfacing as required
assembly to precision OEM Specs
in-house remanufacturing of cylinder heads
new or remanufactured rocker arm assembly
Parts replaced in all Kar King rebuilt engines:
new main and connecting rod bearings
new pistons and wrist pins
new piston rings
new cam bearings
new timing components
new freeze plugs
new or rebuilt oil pump
gaskets – full set
Posted: Thu Mar 27, 2014 2:20 pm
by lannvouivre
Sounds excellent!
Posted: Thu Mar 27, 2014 3:22 pm
by Nasmfell
sciko67 wrote:We bought our vibe last year for under $6000. Automatic, FWD family car. It had 150,000 miles, but it was in great shape. Now that the engine is blown, my options are, fix it cheap and sell it, or fix it right and keep it. As low and silvery as the oil was, I feel this engine is a bag of worms. Not worth the time even if I could fix it. No other decent car is in our price range, and everything else on this car is in great shape, so I think I am confident enough to spend $2000 on a good, low mileage engine, and push it for another 200K miles. Monkey Wrench Racing has one right in that price range. 25-60k miles on it. 2005+ piston design. I believe I could install it myself. Does anyone have advice or insight for me?
Car could not have been in that great of a shape if your engine blew in just under 1 year.
Posted: Thu Mar 27, 2014 4:05 pm
by Raven
[/Car could not have been in that great of a shape if your engine blew in just under 1 year.[/quote]
Read the 3rd post.
Posted: Thu Mar 27, 2014 4:59 pm
by sciko67
Nasmfell wrote:Car could not have been in that great of a shape if your engine blew in just under 1 year.
Unfortunately I let the oil get way too low. I had an overconfidence in the car and let life distract me. Not s mistake I'll make again.
Posted: Thu Mar 27, 2014 5:04 pm
by lannvouivre
At that mileage, it may have begun to burn oil fast enough to get too low before he realized it was happening. I did read that someone's oil consumption got really bad after 100k miles.
Posted: Fri Mar 28, 2014 3:07 pm
by sciko67
Can the transmission be left in place when pulling the engine, our will I have to pull CV shafts and all?
Posted: Fri Mar 28, 2014 3:24 pm
by Nasmfell
sciko67 wrote:Nasmfell wrote:Car could not have been in that great of a shape if your engine blew in just under 1 year.
I see, still if you would have known this engine may have been/is an oil burner, you probably would not have bought the car, right?
Posted: Fri Mar 28, 2014 3:26 pm
by Nasmfell
lannvouivre wrote:Nasmfell wrote:Car could not have been in that great of a shape if your engine blew in just under 1 year.
That's too bad.
Posted: Fri Mar 28, 2014 8:08 pm
by sciko67
End of the day, I'll have a good looking family car with a freshly rebuilt engine for under $8000. I'm optimistic and I'm good with that.
Posted: Fri Mar 28, 2014 8:13 pm
by sciko67
Once again though, does anyone know if I need to pull the transmission to pull the engine, or can I leave it in place? I figure if I have to pull the CV shafts, it will add 6-8 hours to the job. That crap sucks. Can I just disconnect the engine from the transmission and pull it out?
Posted: Sat Mar 29, 2014 1:43 am
by Raven
99.9% sure you need to take out the whole thing. My brother did when he swapped engines.
Posted: Sun Apr 27, 2014 12:55 am
by 03GTMatthew
Sciko67
PLEASE KEEP US POSTED ON THE STATUS.
Also please upload pictures of the steps you took and advice for future vibe owners!!
Your contribution will be very rewarding and knowledgeable.
Also have you ordered the engine from CA.? Is that the final choice?
