Tire Pressure Monitor System
Posted: Wed Mar 19, 2014 6:05 am
Hey all!
I have a feeling that the TPS may be malfunction, as it's always going off even though my tires haven't lost any air.
About a month ago I hit a nasty pothole (that I couldn't avoid or else I would hit incoming traffic) and I dented two rims and I had to replace one winter tire. The rims are steel and the tire is a decent one; not the cheapest but not the most expensive either.
However, since then the TPS monitor keeps going off, and then I check the pressure all the tires are fine. Well, maybe a 1% loss in pressure but that's pretty normal especially in winter.
Do you think that the monitor has to be set somehow? And pressing the pressure reset button doesn't seem to help either.
