Idle Air Control Valve 2zz - READ BEFORE YOU REMOVE IT!
Posted: Wed Mar 05, 2014 12:22 pm
by zrooster99
So this weekend I had decided it was time to clean my IACV - my idle was doing a lot of wandering, and I had tried just about everything else. I removed the IACV from the throttle body, cleaned it out thoroughly (it was definitely sticking!), and re-installed it and a new gasket. I got everything back together (getting those screws tightened back up was a bear!), and gave it a start. The car started and ran just fine, although the idle was still a bit funky and I could hear a vacuum leak. So I let the car run and get up to heat while I was looking for the vacuum leak. The leak was more pronounced on a mild rev, so I gave it a few revs. I was looking for the leak for about 10 minutes or so, long enough for the fans to kick on... I gave it one more rev (no more than 3000 rpms), and BANG CLACK, the engine shuts off! Totally locked up!
Turns out, I failed to align the IACV gasket properly. This allowed coolant into the throttle body - every time I revved the engine, more coolant was dumped into my intake manifold, which then got into the pistons, which then caused something to break. This theory was confirmed when we pulled the intake.
For you own good, learn from my mistake!!!
Re: Idle Air Control Valve 2zz - READ BEFORE YOU REMOVE IT!
Posted: Wed Mar 05, 2014 3:22 pm
by arrowracer76
Hydrolocked.
Damn shame.
Posted: Wed Mar 05, 2014 4:02 pm
by Salsa Guy
Ouch! Yea I'm thinking of doing mine....after this I may not.
Posted: Wed Mar 05, 2014 6:32 pm
by hotbug1776
a little grease just to hold the gasket in it's groove goes a long way. It shouldn't mess with the seal either.
there is also a coolant bypass mod to prevent this from ever happening again.
Posted: Thu Mar 06, 2014 4:25 am
by beemerphile1
Wow that sucks. Thanks for the tip.
Posted: Mon Jul 14, 2014 2:41 am
by ken99287
This is interesting. So as long as I'm careful, it should be ok?
Posted: Mon Jul 14, 2014 6:10 am
by ehoff121
Would there be any symptoms to look for besides rough idle and a vacuum leak?
I'd guess that water getting into the engine would cause a cloud of steam from the tailpipe...?
