				Lug Nuts with the Outside Threads
				Posted: Tue Mar 04, 2014 3:48 pm
				by rockinw
				Looking/Need a full set of Lug Nuts that have the outside threads on them for steel wheels.
				Re: Lug Nuts with the Outside Threads
				Posted: Sun Mar 09, 2014 6:40 pm
				by vibenvy
				Just an FYI for you if you get desperate for these lug nuts, the GM part number is: #88972746. They're a few bucks a piece through GM though.
				Posted: Mon Mar 10, 2014 7:17 am
				by rockinw
				Yea thanxs, I have seen them from a few bucks to over $13 a piece. Just trying not to have to pay the stealership prices.
				Posted: Mon Mar 10, 2014 1:07 pm
				by M1MECHANIC
				you can get then from a junk yard.  look for pontiacs like the sunfire and such they use the same ones to hold the hub caps on also.  this is a way that wont cast much if any money.  you may even be able to find the pontiac plastic caps that go in them also. i use to have a sunfire with the same setup to hold hub cap on and the plastic caps for cosmetics.   hope this helps.
				Posted: Mon Mar 10, 2014 4:31 pm
				by rockinw
				Havn't thought about Sunfire's. I will look for them also. I have not been able to locate any Vibes in my local junkyards.
				Posted: Wed Mar 12, 2014 4:16 pm
				by vibenvy
