Question: How to do a simple drain and fill of coolant?
Posted: Mon Feb 24, 2014 8:47 am
Hello.
I am interested in doing a simple drain and fill of the coolant for my 2007 base Vibe with 89K miles on it.
I am the second owner and I don't believe the coolant has ever been replaced. I am looking for a little advice on this process.
Anyways, I don't have access to any jack stands, nor do I want to buy any at this point, so I was simply going to drain from the radiator plug (white plastic screw) and then refill with Toyota brand coolant (50/50 prediluted mix). I understand this will not drain all of the coolant in the system, but I was going to repeat this process 2 or 3 times.
Originally I called the GM dealer to do it, but they wanted $150 for a complete flush and they were going to put dexcool in it. I told them, I have 2 gallons of Toyota brand coolant I want in it. The GM rep. said "2 gallons isn't enough fluid to do the flush." I said the capacity is only 6.9 quarts, and he said, you need at least a 3rd gallon to maybe have a enough to flush it. I guess they don't use water here to flush things out, because as the GM rep said, "this is Montana and you cannot put water in a coolant system."
Then I called Toyota to see if they would flush it. The guy was a real jackass on a Monday morning. He said, "Why are you putting Toyota coolant in a Pontiac Vibe? That takes dex-cool." I said, "It has a Corolla engine in it." He said, "it is still dexcool in there." I said, "it looks pink to me, not dex-cool orange." He didn't like that response, even though I was courteous. He said they would flush it, but not on a saturday. "We cannot flush coolant on a saturday." That is the only time I could have it done. What a frustrating conversation.
Anyways, I decided to just drain and fill it myself. I was going to do this via the radiator with the 2 gallons Toyota pink coolant I have. I cannot get to the drain plug on the back of the engine, so that is out.
Here is what I was going to do, step-by-step. Please add in any details I miss. My main concern is "burping the system", which I have no idea how to do. Or when to replace the radiator cap and start the car and run it with the heat on.
1. Place drain pan under radiator drain hole in front of car.
2. Unscrew radiator plug.
3. Undo radiator cap.
4. Let fluid completely drain out.
5. Drain reservoir tank if it doesn't drain during this process (Some people say the reservoir will drain, others say, you have to remove the tube from the side of the radiator and push it below the tank to drain the reservoir. Don't know which is true).
6. Add comparable amount of new pre-diluted Toyota pink coolant. I believe it should be about 3.25L? Is that correct?
7. Refill the coolant resevoir next? Or does it automatically refill when I add it directly to the radiator opening?
What is the next step? Start the car and run it with the radiator cap off and the heat on? Or should I replace the radiator cap and then start the car? What should I be looking for on the temperature gauge?
How do I get the air out or "burp" the system?
Any advice for the rest of the process would be helpful. I am trying to keep it simple.
Also, if I go with the above method, how many times should I do this to replace 90% of the original fluid? 3 times?
Thanks everyone.
Thanks everyone.
