Can I dirve it wihtout the belt on?
Posted: Sat Feb 01, 2014 7:55 am
by cjb2145
Recently, the bolt on the tension pulley broke on my 2003 Vibe with 315K, it's the standard 4cyl. for the motor. I need to move the vehicle forward about 15 feet to get it into my garage so I can work on it. With all of the snow and ice this time of year pushing it is a bit difficult and it's an uphill grade from where it sits to my garage. I have already removed the belt and pulley so what I'm wondering is will I do any harm to the motor by starting the vehicle and driving it forward the 15 ft to get it into my garage without the serpentine belt on?
Re: Can I dirve it wihtout the belt on?
Posted: Sat Feb 01, 2014 8:27 am
by Raven
No problem at all. It will run off the battery power for quite a while.
Posted: Sat Feb 01, 2014 8:30 am
by Chiadog
2X, no problem. I've driven my truck that far without any liquid in the block!
Posted: Sat Feb 01, 2014 8:34 am
by Salsa Guy
Be prepared to remove motor mounts. Replacing that tensioner can be a PITA.
Posted: Sat Feb 01, 2014 8:43 am
by cjb2145
Thanks all!
Posted: Sat Feb 01, 2014 9:00 am
by Salsa Guy
Be safe and good luck!
Posted: Sun Feb 02, 2014 2:21 pm
by Water boy
Salsa Guy wrote:Be prepared to remove motor mounts. Replacing that tensioner can be a PITA.
:o
Hope the motor mounts in my 08 1zz FWD are not involved whenever I have to the tensioner.
Posted: Sun Feb 02, 2014 2:59 pm
by cjb2145
I got it in the garage and have removed the mounts. Next weekend I will attempt the bolt extraction.
Posted: Sun Feb 02, 2014 7:09 pm
by thebarber
im late, but you don't want to go far w/o the belt as the water pump won't be running to cool the engine...
Posted: Sun Feb 02, 2014 7:16 pm
by Water boy
OP stated 15 feet.
Not an issue unless the OP does a full warm up of the engine prior to the over 10 foot distance to the garage.
/sarc
Posted: Sun Feb 02, 2014 8:11 pm
by Salsa Guy
cjb2145 wrote:I got it in the garage and have removed the mounts. Next weekend I will attempt the bolt extraction.
Are you talking about the bolt to release the tensioner or the bolt that holds the tensioner to the block?
