Review Tokico Blue Struts (06 Vibe Base)
Posted: Thu Jan 23, 2014 8:42 pm
I purchased my Vibe new in the Summer of 2006.
Here's a timeline of the suspension work that has been done to the car.
Tokico Blue struts are basically stock replacement struts with the same geometry, but different valving to make them firmer than the stock struts. When functioning properly they do that task fine. The car corners flatter, but you feel more of the road. The problem is, on my car, the Front Right strut keeps failing. First at 5k miles, then again after 30k miles. The Tokico Blues were installed because I intended to start Autocrossing. I participated in 11 events after the first broken strut was replaced.
This time the mechanic found both the front rubber strut dust sleeves have holes in them. So the driver side strut assembly will need to come apart to replace that. Going forward I will be recommending these be replaced when the front struts are replaced.
At this time the other three struts seem to be working well. I hope I can get another 30k out of them.
TL;DR: I will not be installing Tokico products on my car in the future, and I will not recommend them to other people.
- 7620 - 9/16/2006 - Installed Progress sway bar
- 125283 - 2/13/2012 - Installed four new Tokico Blue Struts (purchased from eBay), Front strut mounts (the top hat) and front rubber isolators (the rubber thing between the strut and the bottom of the spring)
- 125318 - 2/15/2012 - Four wheel alignment (it only needed the fronts done)
- 130649 - 7/27/2012 - Replaced Front right strut replaced under warranty. I had to pay for installation. The company I purchase the struts from no longer sold this brand, so I had to go through the distributor.
- 161483 - 1/23/2014 - Replaced Front right strut and strut dust sleeve. I had to pay for installation. When I contacted the distributor again to purchase a replacement, they didn't return my phone calls or emails. I ended up purchasing is on Amazon.
- Two wheel alignment, soon.
