V6 or V8
Posted: Fri Jan 10, 2014 10:19 am
by Kinleysman
In everyone's opinion which one of these engines would better suit an 06 Vibe a V6 or a V8?
Which would save more gas because, I really believe that the 4-Cyl does not belong in the vibe, I dont believe that it has the adequate power the car.
Debate on!!!
I want a new motor for my vibe if yall cant tell lol.
Re: V6 or V8
Posted: Fri Jan 10, 2014 10:31 am
by Raven
For the cost of converting a Vibe to V6 or V8 you could buy a real V8 car.
That being said, my brother put a 350 V8 in the back seat of an early sixties VW Bug. It began to fly at over 100 mph, very scary.
Re: V6 or V8
Posted: Fri Jan 10, 2014 11:08 am
power takes fuel. Seems like saving gas and upgrading a Vibe to a V6/V8 are mutually exlusive
I bought the Vibe because at the time it was the best MPG in a US brand vehicle. It is a good compromise of power, economy and utility. If I needed or wanted the power of more cylinders, I'd buy a car designed to have it
That being said, my brother once put a 350 in a Corvair. Doubled the inherent danger of riding in that car
Re: V6 or V8
Posted: Fri Jan 10, 2014 6:17 pm
by SeattleJeremy
Kinleysman wrote:I really believe that the 4-Cyl does not belong in the vibe
The people who designed and build the car from 2002-2010 would disagree with you. Every single Vibe built at NUMMI has a four cylinder engine.
Kinleysman wrote:I dont believe that it has the adequate power the car.
The 2006 Pontiac Vibe (base with manual transmission) power to weight is 1HP to every 21.4 pounds.
Yes, this is on the low side, but a 2010 Mini Copper (base, 6-speed auto) has 1HP for every 22.4 pounds.
It's certainly possible to put a larger engine in the car, but that engine will likely not yield better fuel economy.
Here is a build where they are putting a V8 in a 2005 Vibe.
http://ls1tech.com/forums/conversions-h ... -vibe.html" onclick="window.open(this.href);return false;
Some better questions are:
Do you have something you can drive while your Vibe is under construction (or can you buy a beater for this time period)?
What is your budget?
What is your automotive and manufacturing skill level?
Do you have a particular drivetrain in mind?
Most important What are your goals for the car?
Would a 2ZZ swap from a Vibe GT suite your goals? (Faster)
Would a WRX Wagon suite your goals? (Way Faster)
Would a Jetta Wagon/Golf 5-door Diesel suite your goals? (More power, and more economical)
Would a 2014 Mazda 3 Hatch 2.5L suite your goals? (More power, and more economical)
Re: V6 or V8
Posted: Tue Jan 14, 2014 4:46 pm
by lannvouivre
SeattleJeremy wrote:Would a 2014 Mazda 3 Hatch 2.5L suite your goals? (More power, and more economical)
And don't forget super-sexy! ;)
Re: V6 or V8
Posted: Tue Jan 14, 2014 6:56 pm
by Caretaker
I think the Vibe is perfectly suited for a corolla or camry 4 cylinder engine. It is the pathetic 4 speed transmission that makes the car yesterday's news. A change should have been made to the 2009-2010 models, but Toyota kept dragging their heels on having a 6 speed automatic tranny as standard. Our loss.
Re: V6 or V8
Posted: Fri Jan 24, 2014 5:11 pm
Go for broke and put a V8 in the Vibe. Another member here and on Matrix owners, is doing this exact thing as I write! I hope you have access to a machine shop, tool & die shop, large garage. and a lot of spare change laying around :o If the whole idea behind this hypothetical "upgrade" is because you want to be different, then I admire your thoughts. If you meet the above criteria then DEFINITELY go for it 8-)
Re: V6 or V8
Posted: Fri Jan 24, 2014 5:26 pm
by KITT222
People have done Toyota V6 swaps into Celicas, which has an identical K-frame as the Vibe, so the outline is there for a possible V6 swap. Rumor has it that the second gen is even based on the same Toyota MC platform as the Camry, so a V6 could bolt in. AND the first gen is close to the second gen in the chassis design, so a V6 could cleanly go into a Vibe.
Re: V6 or V8
Posted: Fri Jan 24, 2014 5:45 pm
by Salsa Guy
A Turbo on the 1zz. You'll get MPGs and plenty of power.
