Cold weather and Electronics
Posted: Tue Jan 07, 2014 10:00 am
by Nasmfell
Out of curiosity, since many places have had bitterly cold weather, has anyone experienced electronic issues besides battery with their Vibes/Matrixes, notably with the Drive by Wire System, Electronic steering, etc?
Re: Cold weather and Electronics
Posted: Tue Jan 07, 2014 11:45 am
by bull77
I don't know if it was cold related but my blower motor stopped working last week. No heat or defrost in -35 is not fun
swapped the fuse and bought a new blower motor only for it to start working on a day it warmed up.
Posted: Tue Jan 07, 2014 11:49 am
by beemerphile1
Car in signature;
40,000+ miles
original battery
-12 degrees F this morning
started and ran perfectly
Only thing ever done is oil changes, tire change, and new brakes.
Posted: Fri Jan 17, 2014 2:01 pm
by vibenvy
Both our Vibes are in a heated garage when at home, but when I had to work a couple days when it was below zero here in Chicagoland a couple weeks ago, the Vibe was pretty slow to start and the one day when it was
really cold, the starter made a horrible screeching noise for a split second
. Other than that, both Vibes have been fine with the cold weather though.
Posted: Fri Jan 17, 2014 4:53 pm
by Nasmfell
vibenvy wrote:Both our Vibes are in a heated garage when at home, but when I had to work a couple days when it was below zero here in Chicagoland a couple weeks ago, the Vibe was pretty slow to start and the one day when it was
..well that might be a concern next week. I think more cold "Arctic" air is on the way.
Posted: Fri Jan 17, 2014 7:22 pm
by 09vGT
Mine makes the "screeching" sound also, only when cold. I don't know how else to describe it. It has done this for the last couple of winters.
Posted: Sat Jan 18, 2014 5:36 pm
by vibenvy
Nasmfell wrote:..well that might be a concern next week. I think more cold "Arctic" air is on the way.
Everything I have heard is that it's not going to be nearly as bad as a couple weeks ago though when temperatures were around 25 below zero and wind chills were 40-50 below zero.
09vGT wrote:Mine makes the "screeching" sound also, only when cold. I don't know how else to describe it. It has done this for the last couple of winters.
Mine has only done it a few times when it's been sitting at work all day and it's
really cold out. It doesn't do it normally, so I'm not too concerned about it. It is definitely a horrible sound though
Posted: Sat Jan 18, 2014 8:20 pm
by KITT222
2004 Vibe base, Minnesota - 3rd coldest state in America. Wasn't happy starting below zero the first few times, but now it will turn over with the first crank as low as 5F. No heated garage, just a block heater that's plugged in at night and times when she's at home.
Posted: Sun Jan 19, 2014 4:06 pm
by Nasmfell
vibenvy wrote:Nasmfell wrote:..well that might be a concern next week. I think more cold "Arctic" air is on the way.
I've heard that, but it may last for more days compared to earlier in the month
