				04 vibe will not start
				Posted: Sat Jan 04, 2014 2:44 pm
				by adamheldreth
				got in the car and went to gas station, stopped at stop sign and the car died and will not start again. checked fuel,got fuel,checked spark has spark. ecu is not tripping any codes except for o2 censor. any help would be greatly appreciated.thanks
				Re: 04 vibe will not start
				Posted: Sat Jan 04, 2014 7:08 pm
				by Salsa Guy
				What code is it?  Too assume it's just an O2 sensor could lead to ugly results.
				Posted: Sat Jan 04, 2014 8:25 pm
				by adamheldreth
				it was the same code that was on there before it started doing this. the guy at autozone said its a o2 code other than that i dont know? and it is the 1ZZ-FE btw
				Posted: Sun Jan 05, 2014 5:05 am
				by JohnO
				Was the car completely out of fuel when it died at the stop sign? If so, you could have gotten air into the pump and it is having a hard time priming again.
				Posted: Sun Jan 05, 2014 9:12 am
				by Salsa Guy
				If you don't know the code then it's really hard to say.  You should know what codes it's spitting out, make a note, and not let people just clear them.  I assume it will turn over.  How did you check the spark and fuel?
				Posted: Sun Jan 05, 2014 9:25 am
				by adamheldreth
				yes it will turn over but not start.and no it wasnt out of gas its got a 1/2 tank in it
