Vibe Mirror Turn Signal lights DIY
Posted: Sun Dec 29, 2013 2:39 pm
07/20/14 Added update on forward facing LED's in mirror
Discussion on Genvibe got me interested in adding this option. Wanted to add lights to the door switch panel. Since I would have to take the door apart for that project, this was only one more step. Adding up bits and pieces of information scattered across this site, gave the project a try. Summed up the steps in the video below. Their are many different versions of this modification, add your version to the thread.
Turn signal wires, are 12v off the flasher. They can be tied into directly so long as you so not overload the system. On the flasher, one side has 5 wires the other has 3. On the three wire side there is one wire two blanks and a group of two wires. The wire by itself should be Green with a black trace, this is the Left turn signal. In the group of two wires, the Green with yellow trace is the Right turn signal.
Here is a link on running wires to the door:
viewtopic.php?f=18&t=42830
Here is the video link highlighting steps for adding mirror lights:
http://youtu.be/jp0GUxDBHyQ
If I did it again, I may used a different light option. The strip lights were a tight fit between the mirror edge and housing. When done, I lost a little range in mirror adjustment due to the mirror hitting the strip. Adding LED arrows to the mirror inlay, seemed the best option. With old plastic, did not want to take the chance on damaging the assemblies. Perhaps a series of bright amber LED's behind the mirror to create a ring of light between the mirror and housing would work. Overall the project went well, found another rust spot behind the mirror, had to fix before putting the mirror back on.
UPDATE: Forward facing LED's added, Picture inside mirror housing and then with turn signal illuminated.
Inside showing wiring, not to bad to work on, just keep in mind mirror adjustment motor and mounts
Illuminated front facing LED's
Used 5 amber LED's in series with resistor Ground-LED-LED-LED-LED-LED-Resistor-+12v can fit 6 LED's in mirror housing without issue
Used the following LED's color was a good match with the corner turn signal lights.
5mm Yellow 595 nm, 20 ma, 5000mcd, 30 degree viewing angle LED
http://www.superbrightleds.com/moreinfo ... 0-mcd/287/
Trick with this modification is keeping things weather tight. I used hot glue to seal all the solder connections in the mirror housing. Do not use silicone, it will eat wiring as it produces ammonia. Drilled 3/16" hole for LED's secured them with a dab of hot glue, completed the wiring, then covered everything in hot glue to keep water salt etc from getting in.
