Vibe Courtesy Ground Lights DIY
Posted: Sun Dec 29, 2013 6:45 am
by Derf
07/06/14 Revised Resistor Values changed from 30ohm to 100ohm due to vehicle voltage peaking around 15 volts
After reading several posts and suffering through another winter, where night seems to last 20 hours a day, added courtesy lights to the door bottom. The hard part of the install is getting the wiring from inside the car through the door boot. With the wiring in the place, the rest goes fairly smoothly. The courtesy lights in the 1 Gen Vibe used a ground based activation system. Their is always 12v positive to the roof dome/courtesy lights. When the door opens the cars lighting control module "opens" the ground circuit for the courtesy lights, then after predetermined time increases resistance in the ground (through transistor circuit) to dim the lights. To make this mod it is essential you run two wires for the door lights, one will be 12v the other being the factory on/off ground. Why did the engineers do this? Safety, its easier to protect a ground activated circuit than a +12v source circuit.
In the A pillar (support in front of driver where windshield is attached) you will find the wiring harness running down the pillar. Their is a heavy jacket covering the wiring, use nips or small cutters to remove the jacket, it will be tough. Using this location is not only easier to find the wires, but also make connections. Otherwise you would have to tear apart the dash. Their is also plenty of room at the base of the pillar to drop the wires (feed top down let gravity do the work) behind the dash to connect to the wires you have run out to the door.
A Pillar courtesy wire colors:
Red with yellow trace = Door Trigger (ground activated)
White with Blue trace = 12v positive (on all the time, even with car off)
I pulled new wire, Blue for 12v and Orange for ground, trying to match the factory colors
I chose some high output standard size 5mm LED's, they require roughly a 3/16" drill bit. Used flat tip LED's to maximize placement, a round tip may have interfered with trim or weather stripping.
White wide angle LED's, model: RL5-W15120
https://www.superbrightleds.com/moreinf ... /252/1179/
Resistors: 100 Ohm 5W Audio Grade Resistor
http://www.parts-express.com/100-ohm-5w ... e--015-100
I used a 1 watt resistors in mine, but still thought it was generating to much heat.
Circuit used: Ground-LED-LED-LED-100 Ohm 5w Resistor +12v
Link to handy tool to configure LED's in other series, parallel combinations:
http://led.linear1.org/led.wiz
Rule of thumb when adding LED's to the door:
-think about were you want the light,
-were will the weatherstripping or other parts of the car hit the door,
-how to route wires for later access
-keep out of the cars moving parts or getting pinched.
Video of courtesy door light installation:
http://youtu.be/rII9X2pQBZI
Re: Vibe Courtesy Ground Lights DIY
Posted: Sun Dec 29, 2013 9:46 am
by KITT222
Very clean work. This will help me when I want to add a light to my cargo cover so I can still get light below it (but have it able to unplug from a simple plug if I want to remove the cover).
Posted: Fri Jan 24, 2014 1:51 am
by hoooboy
Great DIY
http://matrixowners.com/index.php?/topi ... nd-lights/" onclick="window.open(this.href);return false;
thanks
Posted: Tue Jan 28, 2014 8:48 am
by hoooboy
What do you think about this option? Cool or not?
I think it should fit because it have enough space at this place.
Courtesy door panel lights from a BMW Z3
Posted: Tue Jan 28, 2014 10:22 am
Nice LED mod and great videos (several posted BTW). One other tip: If/when opening up your door to make any mods, do them ALL at once! Repeated removal of panels eventually will lead to rattles, air gaps, loose fit, etc. I have a few rather unique LED mods on the drawing board for my doors but won't implement them until they can all be done at once.
Posted: Tue Jan 28, 2014 2:19 pm
by Salsa Guy
I've read many of your DIYs. Good Job again! :D
Posted: Tue Jan 28, 2014 7:35 pm
by Derf
hoooboy wrote: What do you think about this option? Cool or not? I think it should fit because it have enough space at this place.
As long at the depth is right, I see no issue. Their is a lot of space between the skin and door. Will you go LED or conventional bulb?
I think many company's put the lights facing out rather than down as a safety feature, alerting passers by that a door is open. My goal was slightly different, I put the lights mostly pointed down toward the ground for visability getting out of the car, with the ones closest to the door hinge pointed toward the ground/footwell with the door open, for getting in the car. Many vehicles have footwell lights, the Vibe does not. Missing that feature, I expanded the project to light part of the interior.
tpollauf wrote:Nice LED mod and great videos (several posted BTW). One other tip: If/when opening up your door to make any mods, do them ALL at once! Repeated removal of panels eventually will lead to rattles, air gaps, loose fit, etc. I have a few rather unique LED mods on the drawing board for my doors but won't implement them until they can all be done at once.
Took your tip, did several mods when adding the door lights... Of course, if the right project shows up may have to open up the door one last time. Putting the sound dampening material on the door and foam strips on the edge were the skin meets the door, really helped firm up the fit. Removing the door the last time I noticed the push tabs are starting to have more give in them.
Hopefully you can have your mods ready for the GenVibe meet. So far I did just the driver door, have to wait until the arctic blast passes before I can resume work on anything plastic.
Posted: Wed Jan 29, 2014 4:37 pm
by hoooboy
I'm going with led bulbs if I install these BMW panel lights.
