Rough idle
Posted: Sun Dec 08, 2013 1:30 pm
Hello,
2005 Vibe with 133,000 miles. Changed the plugs and noticed the spark plug and boot #1 (#1 being the far left when standing at the front of the vehicle looking at the engine) had oil on them.
Changed the vale cover gasket to address the oil issue. Used Denso iridium plugs (original were NGK). Also, changed the air filter.
Started the vehicle up and all seemed well. No oil leaks. Idle then became rough. Vehicle feels like it is about to stall out, but does not. Engine appears to slightly shake. No CEL at present.
Thought is might be a ignition coil going bad (maybe the one that oil on it). Pulled the electrical connector at each ignition coil. Each time the vehicle almost stalled out - which leads me to believe the coils are all working.
Thoughts? I thought about buying a coil and switching it out with each one to see if the engine runs any better. My thought is that maybe one of the coils is going bad, but not bad enough to cause a misfire yet. Also, thought about cleaning the MAF.
Any help or suggestions are greatly appreciated. I do a lot of driving for work and would prefer not to become stranded.
Thanks,
Dante
Thanks,
Dante
