I Want to Make My Vibe Standard.
Posted: Mon Dec 02, 2013 10:10 pm
by GoodVibes1
I have an automatic vibe. I really like driving standard and I really like my car so it would be cool to switch from auto to standard. I have a neighbor that lives down the street that has a 2005 vibe that's standard don't know much about it but he wanted to trade me cars for my automatic back before I had painted the car. But I didn't trade him. But now I just wanted to know if I would be able to get his car and my car together and I and some help from others will try to switch the transmissions. I was wondering if it would be possible for me to do that and I was also wondering how much work I would have to put in it/how hard will it be and any other extra parts I would have to buy. I do not know right now if he has an AWD because I do and his is a 2005 and mines a 2004 if that makes any difference.
Re: I Want to Make My Vibe Standard.
Posted: Mon Dec 02, 2013 10:47 pm
by KITT222
I hate to say it, but since your Vibe is an AWD, there's really no chance of converting without taking most everything drivetrain related out, and redoing a LOT of stuff. The AWD only ever came in automatic. But on the bright side you get AWD-only independent rear suspension.
Posted: Tue Dec 03, 2013 4:29 am
by beemerphile1
Lots of work and money will get it done. I think it would make more sense to sell or trade. Paint job would be easier than swapping drive train.
Posted: Tue Dec 03, 2013 10:17 am
by SeattleJeremy
What are your goals? What is your budget?
If you're looking for a project, and have money to burn, then this is an interesting project. However, the car will be worth less than when you started, have less utility, but will be more fun to drive.
If you have a shop do the swap it's going to be really expensive, like close to how much the car is worth now.
Going off the top of my head, here's what you would need.
  • 5speed (C59) or 6speed (C60) Transmission (6-speeds are cheaper and more fun).
  • Clutch + clutch cable.
  • Master Cylinder / Salve Cylinder / Hydraulic lines
  • Pedals (Brake and Clutch)
  • Gear shifter, shift boot, and knob
  • shift cables to go from the transmission to the shifter
  • both front axles
  • ECU for a manual with ABS, because the AWD ecu watches what the rear wheels are doing and will throw codes.
  • Various Fluids / nuts / bolts / clips / other little things.
Things to think about
  • The FWD ECU might have issues with the pre-cat in the AWD's exhaust manifold.
    If this is a problem you can swap in the FWD manifold and exhaust.
  • The rear wheel bearings might need to be swapped for FWD rear bearings, because when the rear axles are removed there will be a hole.
  • After the rear drive train is removed the rear factory spring rates will be a bit off.
Not having done this I'm certainly missing things.
Everything above this line is possible to do, because 2003-2008 Vibes\Matrix\Corollas are constructed with these parts, and you can LEGO them together.
Now starts the speculation.
2000-2005 RAV4 4x4 came standard with a 5-speed manual (most in the US sold with the optional 4-speed auto). Find out if it bolts up to the Vibe 1ZZ-FE. Most transmission only bolt to the bell housing, unfortunately, AWD Toyota transmissions also bolt to the side of the block.
If it bolts up, you'll need to investigate the following.
  • The front axle output holes are likely in a different spot than the AWD Vibe. If so you will need custom axles.
  • The rear output hole on the transmission is likely in a different spot than the AWD Vibe (also they have different wheel bases). You will need a custom drive shaft.
  • Verify the Final Drive ratio on the rear differential is the same as on the Rav4.
    If not
    1. Find out if the rear differential from the Rav4 fits. If it does but it's a different diameter, you will need custom axles. If it does, but the axle inputs are different, you will need custom axles.
    2. Find out if the Vibe rear diff will accept custom gears.
Posted: Tue Dec 03, 2013 5:54 pm
by Salsa Guy
For AWD project I was looking at All-Trac swap.
