Right front door vibrates from speaker.
Posted: Tue Aug 05, 2003 5:16 am
by Meph
I don't know if there's just a screw loose or of this is a cronic problem or what. I just have the basic Moon & Tunes package.It's just the right front speaker in the door that makes the plastic around it vibrate a bit when the bass hits on certain songs.I made a quick fix by jamming a towel into the little cubby hole in the door, but I want to fix it up proper. The towel being wedged in there just presses the plastic back to prevent the plastic from vibrating.A buddy of mine said that there are insulation products out there that you can put in the door. Spray in types and lay in types, he said.Anyone else have a similar problem? If so, how'd you fix it?
Re: Right front door vibrates from speaker. (Meph)
Posted: Tue Aug 05, 2003 5:23 am
by NovaResource
Yes, this is a common problem. Removing the door panel and adding some foam around the speaker solves the problem.This thread should help with the door panel removal:http://forums.genvibe.com/zerothread?id=785
