Delco Radio Pin Diagram
Posted: Mon Aug 04, 2003 11:18 am
by gragon
Delco radio pin outs for those who need it.
Re: Delco Radio Pin Diagram (gragon)
Posted: Mon Aug 04, 2003 11:41 am
by cohocarl
Thank you very much for posting that. Some of us are curious if the cd changer terminals will accept line level input from like a DVD or mp3 player, or if it is a different type of signal. Do you have any idea?Thanks,Carl
Re: Delco Radio Pin Diagram (cohocarl)
Posted: Mon Aug 04, 2003 12:10 pm
by Jahntassa
If you saw the XM Satellite Radio thread, I have a unit from P.I.E. that will interface.I'm installing it tomorrow, and will post a seperate thread on it. It plugs into the 12 pin on the back of the headunit..to the PIE unit, then to the changer. It will accept three line-ins and has a seperate switch to change between them and the changer.
Posted: Mon Aug 04, 2003 12:24 pm
by gragon
A fellow posted this on the Matrix Owners board and I figured you guys would need it also.
Posted: Mon Aug 04, 2003 11:18 pm
by johnsoax
quote:Delco radio pin outs for those who need it.Thats interesting because my Delphi drawing shows generally the same with a few differences.A1 - Class 2A2 - Class 2A3 - SW_PWRA4 - FM_DET+A5 - GNDA6 - ASWC_REF_OUTA7 - RUI1A8 - LF+A9 - LF-A10 - RR-A11 - RR+A12 - GNDB1 - BattB2 - IGNB3 - ANTSPLYB4 - DIM+B5 - DIM-B6 - AMP_SENSEB7 - RUI2B8 - LR+B9 - LR-B10 - RF-B11 - RF+B12 - PARKM - AUX_MON+L - AUX_MON-K - AUX_COMJ - LAUXINH - RAUXING - CLASS2A - CEL_TEL_MUTEB - Not used (Test Point)C - GNDD - GNDE - Not Used (Test Point)F - Not Used (Test Point)
Re: Delco Radio Pin Diagram (johnsoax)
Posted: Mon Aug 04, 2003 11:19 pm
Could one diagram be the M&T radio, and the other just the base radio?
Re: Delco Radio Pin Diagram (ragingfish)
Posted: Mon Aug 04, 2003 11:45 pm
by johnsoax
Could be, mine is for the in-dash 6-disk M&T radio.
Posted: Tue Aug 05, 2003 12:53 am
by NovaResource
quote:Could one diagram be the M&T radio, and the other just the base radio?There is no "M&T Radio". The M&T package is available with the base single-disc radio or the upgrade 6-disc in-dash radio.
Re: Delco Radio Pin Diagram (NovaResource)
Posted: Tue Aug 05, 2003 4:20 am
by johnsoax
Didn't know that, thanks for the info.
Posted: Tue Aug 05, 2003 7:27 am
quote:There is no "M&T Radio". The M&T package is available with the base single-disc radio or the upgrade 6-disc in-dash radio.Ah. Is it the amp that changes then?
Posted: Tue Aug 05, 2003 7:37 am
by NovaResource
quote:Ah. Is it the amp that changes then?Basically. The "Tunes" part of the "Moon & Tunes" package is an added amp under the passenger seat and the addition of 2 tweeter speakers on the front door A-pillars.
Posted: Tue Aug 05, 2003 7:47 am
Gotcha.
Posted: Tue Aug 05, 2003 7:56 am
by NovaResource
The reason the M&T package is not available with the Nav system is because the Nav system has a 6-disc remote CD changer under the passenger seat where the amp usually goes. There is no room for the changer and the amp. Because you can't split out the moonroof from the M&T package (at least in the US) this is why you can't get a moonroof with the Nav system.
Posted: Tue Aug 05, 2003 7:57 am
Ah. Good to know!
Posted: Tue Aug 05, 2003 8:49 am
by cohocarl
quote:The "Toons" part of the "Moon & Toons" package..."Toons"??? As in Cartoons? Pontoons? I thought it was "Tunes". Get your head out of your amp Nova.
Posted: Tue Aug 05, 2003 11:19 am
by NovaResource
I hate brain fade. Thanks for catching that. I corrected my stupidity.
Posted: Tue Aug 05, 2003 11:38 am
quote:I hate brain fade. Thanks for catching that. I corrected my stupidity.LOL! I thought you intentionally did that.
