Help!!! Lost a ring in my Vibe
Posted: Sun Aug 03, 2003 9:34 pm
by Sub-Vibe-R
Ok, to make is short and simple, I was cruising in my Vibe, with my gf and my kid, ands I heard a stange noise. I took a look at my gf and she told me my ring slip from my hands I thought, it falled down under the seat that's all. So arrived at destination, I started searching the precious ring. I looked everywhere, nothing. I even removed the center console, nothing, nada niet!!!! The only places I haven't been able to check is under the floor mat and in the air duck.Anyone has any clue how to get those place without destroying the half of my car????
Re: Help!!! Lost a ring in my Vibe (Sub-Vibe-R)
Posted: Sun Aug 03, 2003 9:55 pm
by msmyer
quote:Ok, to make is short and simple, I was cruising in my Vibe, with my gf and my kid, ands I heard a stange noise.Obviously, this wasn't a wedding band! Do you have the Moon and Tunes Package? Look underneath the amp! I find loose change there, when I clean my car out! Good Luck!
Re: Help!!! Lost a ring in my Vibe (msmyer)
Posted: Sun Aug 03, 2003 10:13 pm
by Sub-Vibe-R
quote: Obviously, this wasn't a wedding band! In fact, she lost the ring I gave her for the Valentine day....[quote] Do you have the Moon and Tunes Package? Look underneath the amp! I find loose change there, when I clean my car out! Good Luck! Nope. I do not have M&T package. I even pass the aspirator to "suck" it. Still no luck.
Posted: Mon Aug 04, 2003 11:49 am
by micheles_bad_vibe
hey wait... moons & tunes has an amp??
Re: Help!!! Lost a ring in my Vibe (micheles_bad_vibe)
Posted: Mon Aug 04, 2003 12:00 pm
Yep. It's the silver box under the passenger seat.The silver box under the driver seat is the power inverter for the AC outlet.
Posted: Tue Aug 05, 2003 2:10 am
by cool vibes
I would check where the seatbelt is,down inside the cover next to the seat"" good luck in finding it,it will show up
Re: Help!!! Lost a ring in my Vibe (silverawd26)
Posted: Wed Aug 06, 2003 2:21 am
by Sub-Vibe-R
quote:have you tried looking inbetween the seats... As in where the top and the bottom meet? Oh yes I did. Nothingquote:Otherwise I would advise you to take the front seats out and see then. I thought about this. But I have the wright tool and the bolt was very tight.I'll try to take a look under the seat. There's a peice of metal and may be it is stuck between the air foam and this piece of metal.
Posted: Wed Aug 06, 2003 2:44 am
by Hot Vibe
Zip over to the autoparts store and buy the magnet on a stick. That tool is invaluable. A strong magnet that mechanics use to retrieve dropped wrenches or nuts inside the engine compartment. There is also a mirror on a stick. They both are very yummy.
Re: Help!!! Lost a ring in my Vibe (Hot Vibe)
Posted: Wed Aug 06, 2003 4:17 am
by Sub-Vibe-R
quote:Zip over to the autoparts store and buy the magnet on a stick. That tool is invaluable. A strong magnet that mechanics use to retrieve dropped wrenches or nuts inside the engine compartment. There is also a mirror on a stick. They both are very yummy.Good idea!! I'm thinking about getting this toll for years now but I never bought it yet. It is always usual.
Posted: Wed Aug 06, 2003 5:03 am
by Sub-Vibe-R
quote:What metal is the ring made out of?If it is a precious metal, forget it..It will not be attracted to the magnet. Your wright Silver. gold won't stick on the magnet....What can I do???? Buy another ring to my gf of starts destroying my Vibe to, may be, find it out???
Posted: Tue Oct 07, 2003 1:16 am
Ben, been 2 months, did you ever find the ring? ?
Re: Help!!! Lost a ring in my Vibe (joatmon)
Posted: Thu Jul 29, 2004 10:32 pm
by Sub-Vibe-R
Almost 1 year later, I decided to destroy the interior of my Vibe and remove everyting inside the car. I big thank you the Ragingfish for the instruction on removing the center console.So I removed the 2 front seats, the center console, the AC converter and removed the carpet.I found nothing under the carper but dust....So decided to remove the heating pipe located under the driver's seat. I shaked it and heard a hitting sound. I put my hand under, turn it and TADAM the ring appeard!I really don't know how it is possible to an object to fall down and jump directly into this pipe, but is seems to be.
Posted: Thu Jul 29, 2004 10:36 pm
by Mr. Poopypants
I think your best bet may be the air duct.*edit* apparently I missed the part where you found the ringI am going back to licking the window on the short bus now.
Posted: Thu Jul 29, 2004 11:48 pm
cool, glad you finally found it
Re: Help!!! Lost a ring in my Vibe (Mr. Poopypants)
Posted: Fri Jul 30, 2004 4:08 am
by Smokin' Rubber
Quote, originally posted by Mr. Poopypants »I think your best bet may be the air duct.*edit* apparently I missed the part where you found the ringI am going back to licking the window on the short bus now.Lol *image pops into head* man that one really mad me laugh
