Posted: Sat Aug 02, 2003 5:04 am
by micheles_bad_vibe
Re: gas pump (micheles_bad_vibe)
Posted: Sat Aug 02, 2003 6:11 am
by msmyer
Nope! Weird!
Posted: Sat Aug 02, 2003 6:41 am
by NovaResource
It must be you. No problem here either.
Re: gas pump (NovaResource)
Posted: Sat Aug 02, 2003 7:24 am
by Vibe Rater
Try standing on your head.
Posted: Sat Aug 02, 2003 9:07 am
by JustinVGT
Yes, I've had the same problem quite a few times. Some pumps or stations are worse than others.
Posted: Sat Aug 02, 2003 10:53 am
by DavidPIL
Hi MicheleNot too much of a problem with the pump staying on though I did notice the pumps with the heavy duty rubber gooseneck thingie (not the standard metal only) seems to not fit right. That has to be a universal thing though. I have noticed that the pump does kick off early on my Vibe. I know you're not supposed to top off but I do and found that I could put in nearly 2 more gallons before I started to see the gas through the vent holes. Ok, that might be a bit too full but I'm thinkin that's an awful lot of space left to be filled. I'm guessing maybe there is a longer tube to the gas tank than I'm used to. In any case, that's a lot of gas.Dave
Re: gas pump (DavidPIL)
Posted: Sat Aug 02, 2003 11:09 am
Posted: Sat Aug 02, 2003 12:05 pm
by philndz
I always top off quite a bit....then the gas guage stays over F for a long time....(makes me feel all warm inside )
Re: gas pump (philndz)
Posted: Sat Aug 02, 2003 12:59 pm
by DavidPIL
hiya...hehehe, yeah... the first time I did that, I was used to going around 80 miles before it hit the quarter mark. I think I was still on full at 90. I thought I screwed up the float thingie in the tank. heheDave
Posted: Sat Aug 02, 2003 1:21 pm
by huy397
Never happened to me Maybe it's the nozzle ? Go to a differnt gas station and try again?
Re: gas pump (huy397)
Posted: Sat Aug 02, 2003 2:08 pm
by good vibes
Nope, Nope, Nope. Have your dealer check it out, it could be an emissions problem. I had this issue on my Vibe, it turned out that it was a vent from the topside of the gastank. It may just be bad luck with your gas stations, but I'm thinking that it is this. LAter, and I hope this helps ya out.Rob
Re: gas pump (good vibes)
Posted: Sat Aug 02, 2003 2:31 pm
Posted: Mon Aug 04, 2003 1:24 am
by etoop
I'm driving a 2003 Aztek at the moment (24 test drive). Yes I'm still getting a Vibe soon.. Just having fun driving other cars during the 24 hour test drive promotion. I got gas this morning and I couldn't still the handle all the way in or it would stop right away also. I finally found a spot in which it would let me set the auto pump and walk away...but it took a minute. So I think it is a pontiac thing
Re: gas pump (etoop)
Posted: Mon Aug 04, 2003 2:28 pm
How's the shoebox on wheels working for ya etoop?
