solved: AWD Transmission compatibility? 06>03 it works!
Posted: Fri Nov 08, 2013 11:34 am
by Bad Vibe
trying to sell my 06 awd tranny potential buyer has 03, i know the engine is all the same ands its still a U341F code trans so it will likely bolt up but i'm only seeing a 03-04 p/n a 04-05pm and an 05-06 p/n are these interchangeable or do sensors need to be swapped or is it nfg? any solid info would be appreciated so i can collect my $ with a clear conscious
Re: AWD Transmission compatibility? 06>03
Posted: Tue Dec 31, 2013 8:08 am
by Bad Vibe
P.S. it worked fine, externally identical only had to swap the shift selector on front of trans due to different connector and the trans takes 4 qts of atf instead of 3
