My friends drew on my car windows
Posted: Fri Nov 08, 2013 10:08 am
by tkenway
With that window marker crap. How do I get it off? It's all over my hatch window and back windows. I would like to remove it and have been unsuccessful thus far.
I would prefer not using anything rough, abrasive, or otherwise damaging to the car and you guys have been really helpful each time!
Re: My friends drew on my car windows
Posted: Fri Nov 08, 2013 11:46 am
by kumquat
tkenway wrote:With that window marker (removed). How do I get it off? It's all over my hatch window and back windows. I would like to remove it and have been unsuccessful thus far.
Actual window marker? Any standard glass cleaner with ammonia should work.
Posted: Fri Nov 08, 2013 11:48 am
by ehoff121
You can also use fine steel wool on glass (not paint!), available at your local big box hardware store in the sandpaper aisle.
Razor blade scrapers will work, but be careful not to dig the corner of the blade into the window.
Posted: Fri Nov 08, 2013 12:48 pm
by tkenway
kumquat wrote:Actual window marker? Any standard glass cleaner with ammonia should work.
I'll try this first.
ehoff121 wrote:You can also use fine steel wool on glass (not paint!), available at your local big box hardware store in the sandpaper aisle.
And then this, depending on if option one fails. Thanks, guys!
Posted: Fri Nov 08, 2013 4:24 pm
by jake75
You could also try a windshield deicer - it is alcohol based which is a solvent as well. Shouldn't do any harm.
Next option is something like "Goof Off".
Posted: Sat Nov 09, 2013 11:47 am
by Water boy
I would use 90% alcohol.
Posted: Sun Nov 10, 2013 3:46 pm
by vibenvy
I would start with a razor blade along with some window cleaner. If that doesn't work, I'd keep trying some different liquids along with the razor blade i.e. rubbing alcohol, WD-40, etc. If all else fails, a clay bar should probably work pretty well. I've removed paint overspray from vehicle windows with a clay bar before.
Posted: Thu Feb 20, 2014 9:25 am
by tkenway
So far, it hasn't worked. Due to the beautiful NE Ohio winter weather, I fear it's beyond help.
Posted: Mon Mar 31, 2014 2:08 am
by jolt
Try Bon Ami powder cleaner. I use this on my windows. Do NOT use Comet Cleaner, as Comet will scratch the glass. Bon Ami is good at getting the windshield crystal clean. Here is a link so you use the right stuff: http://www.bonami.com/
You could try that Goof Off solvent for removing marker from painted wall and then finish with the Bon Ami power.
