New Engine Mounts: GM or Toyota Dealer?
Posted: Wed Nov 06, 2013 10:26 pm
by bwflorida
I'm thinking a Toyota dealer might have more experience doing that work than a GM dealer, so does it make any difference where I get new engine mounts on my 2006 Vibe?
Also, is there any engine mount upgrade I should ask for, or just go with the ones the dealer normally installs?
Re: New Engine Mounts: GM or Toyota Dealer?
Posted: Thu Nov 07, 2013 10:51 am
by SeattleJeremy
Engine mounts are going to be most expensive at the GM dealer, because they buy them from Toyota, put them in an ACdelco box, and ship it to the dealers. Second most expensive Toyota dealer. Sometimes the national chain auto stores are more expensive than the Toyota dealer but not always. Least expensive will be online parts stores like Rockauto, they sell OEM quality products, but at a lower cost, because it doesn't have TOYOTA marked on the part.
If you tell us what engine, transmission, and if it's AWD or not, we can help you find the right engine mounts.
Here are some links for you to look at.
http://www.gmpartsdirect.com/" onclick="window.open(this.href);return false;
http://www.toyotapartscheap.com/" onclick="window.open(this.href);return false;
http://www.oreillyauto.com/" onclick="window.open(this.href);return false;
http://www.rockauto.com/" onclick="window.open(this.href);return false;
As for having them installed.
Motor mounts are one step up from doing brakes. Any shop that does any work on engines can perform this service. The GM dealer would likely be cheaper than Toyota because some Toyota service departments charge a premium to work on a "Non-Toyota" car. Call your dealers and get a quote.
Also, try calling around to other auto repair facility in your area, you'll be surprised how much the price can vary. Consider non-national chain stores, as they will normally have less overhead and better prices.
Ask for a quote on the labor cost, and how much they charge per hour.
There is a small, one man, auto repair shop near my house that does all the work on my Vibe. He does everything from oil changes and brakes to full engine replacement.
A job like this is the perfect opportunity to try a small business in your area. The recession killed off some small shops, but that means the good ones should still be around.
As for motor mount "upgrades" there is only one. Polyurethane engine mount inserts. These fill the empty area around the rubber mount with Polyurethane. They make it so the engine doesn't move around as much under hard acceleration and braking. They also make it pretty unbearable at idle. I had these mounts installed last spring before the autocross season started, then had them uninstalled as soon as the autocross season was done. Poly engine mounts should really only be used for race cars.
Here is a link to the ones I have.
http://www.monkeywrenchracing.com/produ ... cts_id=482" onclick="window.open(this.href);return false;
Posted: Thu Nov 07, 2013 3:00 pm
by bwflorida
SeattleJeremy wrote:Engine mounts are going to be most expensive at the GM dealer
Great information for anyone facing this repair. Thanks!
Posted: Thu Nov 07, 2013 5:09 pm
by SeattleJeremy
Just wanted to add an example for the prices.
The MSRP's listed below are the price you will be charged if you walk into the parts department of most dealers.
The item below is the Right Engine Mount for a Vibe/Matrix 1.8L, FWD, Automatic transmission.
Website - Part name - MSRP - Online price.
Gmpartsdirect - MOUNT Vibe; w/o AWD; Auto Trans; Right 1.8L, W/O GT MODEL - $367.87 - $218.09
toyotapartscheap.com - MOUNT Matrix; Right; w/o AWD 1.8L, W/O HIGH OUTPUT - $147.37 - $117.90
oreillyauto.com - Anchor - Engine Mount 9164 - $149.99
oreillyauto.com - Beck/Arnley - Engine Mount 104-1736 - $119.99
Rockauto.com - DEA Part # A4221 - $59.99
Rockauto.com - ANCHOR Part # 9164 - $62.79
Rockauto.com - BECK/ARNLEY Part # 1041736 - $70.79
Notice the Anchor and Beck/Arnley parts have the same part number at O'reilly and Rockauto, but the price difference. Of course you'll be paying for shipping at Rockauto, but it's still going to cost way less.
Posted: Thu Nov 07, 2013 7:07 pm
by kumquat
Amazon has the Beck/Arnley for $71.71 with Prime, and the Anchor 9164 for $50.29 free shipping. The DEA A4221 is $42 shipped.
Amazon is a great place to get car parts, especially if you have Prime.
Posted: Fri Nov 08, 2013 11:49 am
by SeattleJeremy
kumquat wrote:Amazon has the Beck/Arnley for $71.71 with Prime, and the Anchor 9164 for $50.29 free shipping. The DEA A4221 is $42 shipped.
That's a great deal! Shipping auto parts can be expensive.
