SRS Airbag light on constantly after warranty work
Posted: Sun Nov 03, 2013 4:20 pm
Hey everyone, I am new to this forum and this is a somewhat lengthy post so please bear with me.
Car: 2003 Pontiac Vibe base model 5 speed manual trans.
Problem: 6 months ago I had an electrical filter (harness) installed by a dealership in accordance with a GM safety recall (and Toyota - since the car is pretty
much a re-badged Toyota Matrix). This harness is supposed to filter out electrical noise that could possibly cause the inadvertent deployment of the
airbags. Everything seemed fine after I had this done- no problems. Well about 2 months later, the airbag light came on and wouldn't turn off. Took it back
to dealership - they used scan tool - said DTC was B1101 - said the problem was in the module. I used a jumper to read code myself - I get a DTC 15 -
voltage problem. I have checked the instrument fuses and the engine compartment fuses - all good. Horn and switches on the steering column all
work(so I doubt clock spring problem). I have not checked the relays in the engine compartment nor the ones that plug directly into the srs control
module. I have tried to turn the light off myself using the factory service procedure (jumper wire) but I can't get this work. I need the light to be
operational in order to pass a Virginia state inspection (light must turn on and then turn off after approx. 6 sec.). I never did have a battery/starting
problem with my vibe (which I am quite fond of btw) and the battery is a 2 y.o Optima red-top.
So my questions are -
1) Has anyone here experienced a similar problem? Could you describe your particular issue in detail please?
2) Possible solutions (other than taking it back to the dealership)?
A lot of folks here know quite a bit more about this than I do and I would be most appreciative of any help offered. I am not a "pro" just a weekend wrencher who is trying to avoid being taken advantage of by the dealership
Thanks.
Thanks.
