				03 gt rear mounted t3/t04e very fast !!!
				Posted: Sun Oct 27, 2013 6:27 pm
				by revstohigh
				Re: 03 gt rear mounted t3/t04e very fast !!!
				by revstohigh
				here is the dyno sheet from the original set up the pipes are much smaller now so it spools a lot faster, also the turbo has been swaped from a t3 cx racing ebay turbo to the current t3/t04e turbonetics , the only thing left to do is swap the turbine housing fromm a .63 to a .48 and a little more fine tunning of the maps
				Posted: Mon Oct 28, 2013 4:09 am
				by hotbug1776
				This, in tandem with my supercharger, would rule the world!!! Best of all worlds, I can keep the header, slightly modify the exhaust, and only have to modify the intake. Now, just to not be laid off...
				Posted: Mon Oct 28, 2013 8:32 am
				by KITT222
				I was just thinking what a rear-mount turbo would be like on a Vibe. Interesting setup. If you used a smaller turbo, would you get better spool times?
Not sure if snow would agree with this setup. But it seems a little easier... No need to mess around behind the engine. No need to go at the header. A little cooler, too. I'd need some guard and box to keep road debris and water away from everything, and possible winter beater if I did this.
				Posted: Mon Oct 28, 2013 4:31 pm
				by mac99d
				Looks cool...post a pic of the Dyno sheet.
				Posted: Mon Oct 28, 2013 8:35 pm
				by mac99d
				Are you using a inter-cooler?
				Posted: Tue Oct 29, 2013 12:56 am
				by revstohigh
				No Intercooler , the pipes are so long i dont need one it cools down on its way back to the front . my intake temps on a 75 degree day were  125 after a few runs . on a 50 degree day they are around 85
ill post dyno pics soon
				Posted: Tue Oct 29, 2013 1:03 pm
				by SeattleJeremy
				revstohigh wrote:I now have 1-3psi at 3k and full boost by 5k
OK, I'll bite, how much boost is full boost?
Are you regulating the boost to keep it under 10psi?
Also, are you doing something to keep water out of the filter on rainy days?
				Posted: Tue Oct 29, 2013 4:39 pm
				by revstohigh
				i have an internal wastegate set to 8psi so max boost is 8psi
i may put a shield around the filter but for now the filter is just right on the turbo, not realy much worse than a cold air intake in my opinion esp considering how high it sits , the cold air intake i had was in the fender well but sat at least a foot lower to the ground
				Posted: Thu Nov 07, 2013 1:49 pm
				by revstohigh
				dyno sheet is posted above in 2nd post
				Posted: Wed Nov 13, 2013 5:07 pm
				by SeattleJeremy
				Hey, how is the tuning going with the new piping and Turbo?
				Posted: Thu Nov 21, 2013 8:58 pm
				by revstohigh
				Its going great the wot tunning is a breeze if you use the data logger . Part throttle tunning is a bit tougher . But its getting there . Im about to lower my boost and go back and retune in steps at diff boost levels ,that will make it easier to fill in the wholes. But the smaller pipes made a huge difference i have 1-3 psi by 3k and 8psi by 4500
				Posted: Wed May 21, 2014 7:47 pm
				by revstohigh
				traded my baby away today for an outback 2.5xt with much lower millage
				Posted: Thu May 22, 2014 9:18 am
				by SeattleJeremy
				revstohigh wrote:traded my baby away today for an outback 2.5xt with much lower millage
Sad to hear it's gone. The Outback XT is a really good choice. More torque down low, and all wheel drive, but a little more weight.
				Posted: Thu May 22, 2014 10:31 am
				by revstohigh
				what i really wanted was a forester xt but it was a straight trade and the legacy is worth alot more since it has 80k less miles and is newer
				Posted: Sun May 25, 2014 7:23 pm
				by lannvouivre
				Awww man, and I really wanted your AEM piggyback!
				Posted: Sun Jun 15, 2014 5:55 pm
				by revstohigh
				if anyone is going turbo ill gladly email the fic tune for a 2zz with 550inj
				Posted: Sun Jun 15, 2014 5:56 pm
				by revstohigh
				ps i should have kept the vibe lol my new car already blew the engine :-/
				Posted: Mon Jun 16, 2014 10:01 am
				by SeattleJeremy
				Seriously? That was fast.
				Posted: Wed Jun 18, 2014 7:34 pm
				by revstohigh
				it had a bad turbo when i bought it and some of the shiny bits clogged the left cylinder heads oil supply, i get it back with a new engine, full exhaust intake and stage 2 tune tomorrow !
so exited i can hardly contain myself lol
				Posted: Wed Oct 12, 2016 6:54 pm
				by Fatpaul
				Pm sent
