Shift light
Posted: Wed Oct 09, 2013 10:00 am
by vibe_mike
Hi everyone,
I was trying to install a shift light in my 09 vibe, and it has to be connected to the ECU rpm indicator wire. Does anyone know which wire this is, and an easy spot I could connect to??
Thanks.
Re: Shift light
Posted: Fri Oct 11, 2013 5:23 am
by vibe_mike
So I ended up talking to some other people, and found a way to do this in case any one is interested. At the data link connector on the drivers side, the gray wire (pin 9 in the 16 pin plug) is the tachometer, so you can run the shift signal wire off of that.
Re: Shift light
Posted: Fri Oct 11, 2013 7:40 am
by KITT222
Sorry I missed this. I would have referred you this:
https://www.youtube.com/watch?v=wL2CZ26ltlM" onclick="window.open(this.href);return false;
