Front End Problem?
Posted: Wed Oct 09, 2013 9:17 am
by MadJoe
First time I've ever owned a Vibe. Recently bought an 03 with 126K miles. When driving on bumpy roads the front end is not very smooth. Is this a common problem? I hear a front end rattle when I hit a bump.
What should I look for? I know the rear struts were replaced but not the front.
Thanks
Re: Front End Problem?
Posted: Wed Oct 09, 2013 9:22 am
by kumquat
Probably just a loose plastic shield. My girlfriend's 2010 Corolla developed a front end rattle when hitting bumps. Just turned out to be a plastic splash shield rattling against the bumper. A stainless steel self-tapping screw solved that pretty quick.
Posted: Sun Oct 13, 2013 10:43 am
by lannvouivre
Check the front sway bar links as well, those sound really horrible when they're loose.
Posted: Sun Oct 13, 2013 5:35 pm
by jake75
When I first saw this post I thought perhaps I got on the Viagra website by mistake.
Posted: Mon Oct 14, 2013 3:16 pm
by vibenvy
jake75 wrote:When I first saw this post I thought perhaps I got on the Viagra website by mistake.
Posted: Thu Oct 17, 2013 12:54 pm
by MadJoe
Thanks for the replies. No loose front shield. Are these cars suppose to ride quiet when on rough roads or does someone else have any more ideas?
Will check sway bar links.
Thanks again.
Posted: Thu Oct 17, 2013 1:26 pm
by SeattleJeremy
Typical road noise is more pronounced in a Vibe, vs other cars, due to it's limited sounds deadening.
However, you should not be hearing rattling noises coming from the suspension.
Posted: Thu Oct 17, 2013 9:10 pm
by jake75
SeattleJeremy wrote:Typical road noise is more pronounced in a Vibe, vs other cars, due to it's limited sounds deadening.
The rattling noise comes from the steering column according to what I read here. I have it on my 2009 - not on a smooth road, but on the typical uneven road especially in city driving.
Posted: Fri Oct 18, 2013 10:52 am
by ehoff121
Try checking the contents of the compartments in the front end, e.g., under the left end of the dashboard, under the gear shift, the glove compartment.
Things can rattle around in those when going over bumps.
Even 3 coins loose in the coin holder can start vibrating after a while...
