Jon's 2009 Ultra White Base
Posted: Sun Oct 06, 2013 1:01 pm
by kumquat
Picked up 9/20/2013 used with 99,000 miles. Here it is the day I picked it up:
Mods:
9/24/13 Bushwacker rear bumper protector (34011)
9/25/13 Yakima Q-tower rack w/48" crossbars and fairing
9/30/13 GM All-weather cargo mat (19170827)
9/30/13 JVC KD-X50BT receiver
10/1/13 Switch that turns on dome lights
10/1/13 Permanent mounts for GPS and phone
10/14/13 GM Splash Guards (19170820)
10/23/13 GM roll-up cargo cover (19171208)
4/18/14 Curt 12228 Class 2 trailer hitch
4/20/14 Wiper switch with intermittent adjustment (19184827)
7/22/14 Replaced lower center console cubby with Matrix clock
Some pics:
Future stuff:
Fog lights
All-weather floor mats
Footwell LEDs
Glove compartment LED
Re: Jon's 2009 Ultra White Base
Posted: Mon Oct 07, 2013 3:20 pm
by vibenvy
Looking great so far Jon! I look forward to seeing more updates from you and your Vibe
Posted: Mon Oct 14, 2013 11:22 am
by kumquat
Posted: Mon Oct 14, 2013 12:43 pm
by Rayven01
Do those actually work? I've been debating flaps on mine and those things seem so tiny that I'm skeptical.
Posted: Mon Oct 14, 2013 2:33 pm
by kumquat
Rayven01 wrote:Do those actually work? I've been debating flaps on mine and those things seem so tiny that I'm skeptical.
They extend about 2" below and 1" out from the car. When I put them on, I noticed a lot of little scratches and paint chips in the area that the guards would have clearly prevented. That little white piece behind the front wheels had taken a good bit of obvious damage and there were a few small scratches near the leading edge of the door too.
They definitely seem like they'll help out.
Posted: Mon Oct 14, 2013 3:14 pm
by vibenvy
I definitely think the mud flaps make a huge difference. I just wish they made the GM molded ones for the 2009-2010 Vibe GT
Posted: Mon Oct 14, 2013 3:26 pm
by kumquat
I also waxed the car today.
Waxing a plain white non-metallic car presented a rather unique challenge. It was like an elaborate magic trick where no one, least of all the magician, knows what the trick actually is.
Posted: Wed Oct 16, 2013 7:28 am
by Rayven01
I feel your pain. A handheld light you can aim to find dull spots makes it easier.
Posted: Wed Oct 23, 2013 2:44 pm
by BaseWhiteVibe
Wow dude I just realized that you and I have the same spec vibe! You even put the splash guards on! Best way to go!
I ended up tinting the back windows and am glad that I did. I also put Celica wheels on mine and got ride of the steelies, hub caps and ended up bypassing the tire pressure sensor FOREVER
My car needs a waxing BADLY! It has nothing but hard water ALL OVER IT! Took a while to get it off the windows with bar keepers friend but I won't chance it on the paint.
I also like your roof rack. Good choice! I ended up going OEM but yours works for sure!
Awesome car!
Posted: Wed Jun 18, 2014 4:16 am
by kumquat
Someone asked about my phone/GPS setup, and I answered in that thread, but C/P here for reference:
I've switched to a universal phone mount. The one I'm using is the Kenu Airframe, which is stone cold awesome. Easy quick one-handed mounting and removal of the phone and it holds securely.
http://www.kenu.com/products/airframe" onclick="window.open(this.href);return false;
I've attached the Kenu Airframe to the dash by:
1) Installing a Garmin-style sticky back ball mount to the Passenger Air Bag display area:
http://www.amazon.com/gp/product/B004MG ... UTF8&psc=1" onclick="window.open(this.href);return false;
2) Cutting off the excess portion of a regular Garmin Nuvi bracket and gluing it to the back of the Kenu with some epoxy:
http://www.amazon.com/Suction-Cradle-Ho ... vi+bracket" onclick="window.open(this.href);return false;
For the GPS, all I did was buy a length of thin steel bar from Home Depot, then cut off a section about a foot long. I bent it into shape and used a pair of small bolts on each the top and bottom to affix it to the cubby portion of my stereo's dash mount. The GPS is attached with mounting tape.
Posted: Wed Jun 18, 2014 4:34 am
by gtv237
Very beautiful vibe. Could you please post a little more info on your dome light switch and intermitten wiper switch?
Posted: Wed Jun 18, 2014 5:13 am
by kumquat
Sure. The wiper switch is just a straight part swap from a Corolla/Prius/Vibe GT/Matrix. Part numbers:
ACDelco: D6334E
GM 19184827
Thread reference:
viewtopic.php?f=18&t=40099&p=475159&hil ... 4E#p475159" onclick="window.open(this.href);return false;
Dome light switch (I'm working from memory here):
There's a purple wire running to the driver's door jamb button/switch. When the door is opened, this switch connects the purple wire to ground. I spliced a wire into the purple wire and ran it over to the little cluster area where the traction button is. I installed a switch over there that, when activated, connects that wire to ground (there was already a ground point installed under the dash for my remote start, but it's easy enough to use an existing bolt or to drive a self-tapping screw into the sheet metal down there somewhere).
Long story short: put a splice into the wire going to the door switch, then install a switch that when flipped connects this wire to ground.
Posted: Wed Jun 18, 2014 5:20 am
by gtv237
kumquat wrote:Sure. The wiper switch is just a straight part swap from a Corolla/Prius/Vibe GT/Matrix. Part numbers:
ACDelco: D6334E
GM 19184827
Thread reference:
Awesome! But one question, does the door ajar light come on when you flip the switch?
Posted: Wed Jun 18, 2014 5:46 am
by kumquat
It does, yeah. It also makes the lights fade in rather than just come on. It's certainly not an ideal solution, but I saw no other way to actually accomplish what I want without having to find and splice a lot more wires.
Posted: Tue Jul 22, 2014 11:50 am
by kumquat
Swapped out the tiny cubby for the clock from the Matrix today. See this thread for details:
viewtopic.php?f=18&t=43514&p=498032" onclick="window.open(this.href);return false;
