Voltage drop at idle
Posted: Sat Oct 05, 2013 6:48 pm
Hey gang! Long time, no post
My 2006 base Vibe just had the OE battery replaced a few weeks ago after a few slow turn-overs. Autozone load tested and said it was done.
Fast forward to this week: I start my car, turn on the lights, then turn the a/c on and the lights dimmed. Hmmm! Alternator time?
I have the ScanGauge2 plugged in, so I look at the real-time voltage. It's reading 13.8ish mostly, until I turn the lights on (radio off, blower/compressor off), then the voltage dips to 12.4 at idle (it's back up to 13.8 when driving). Autozone tests it and says bad regulator... we order a new one.
My husband pulls the OE alternator and replaces it. It's still doing the same thing! Same readings, same light dim.
He has Autozone bench test the old alternator, and they fail it, then test it again and pass it?! They also tested the new one, and said fail, then pass. Husband thinks the guy just didn't know how to work the new tester. I'm thinking of taking it around to Pep Boys to see what they say on the bench test...
But wondered what else you guys think we should be checking.
Thanks in advance!
Diana
Thanks in advance!
Diana
