				Tire offset question
				Posted: Sun Sep 22, 2013 6:25 pm
				by binder
				Are the rims from an 07 Corolla the same as from an 06 Vibe?  I assume they are, just want to make sure there is not an offset difference?
Thanks
				Re: Tire offset question
				Posted: Sun Sep 22, 2013 8:18 pm
				by Chiadog
				Exact wheel information per make/model/year can be found at tirerack.com!
				Posted: Mon Sep 23, 2013 12:12 pm
				by binder
				They dont list a 15" rim  for the 06 Vibe there?
I was hoping to get some 195 65 15 winter tires and rims, can I not use that size?
				Posted: Mon Sep 23, 2013 12:29 pm
				by Chiadog
				You can! I think. I plan to do the exact same thing. Generally, most or all 15" Toyota wheels with 5X100 bolt pattern will work. Look up the specific Toyota model on tirerack.com and compare wheel spec.'s to the Vibes' 16" spec.'s. In my opinion offset is not critical. Vibe base offset is 54mm. An offset of 30mm will simply put the tire tread about 1" further out from stock. Right Guys/gals?
				Posted: Mon Sep 23, 2013 10:29 pm
				by 10vibe
				I was thinking the base 1.8 5x100 offset for both generations was +39mm.  I could be wrong.  Need to research this, on this site and others.  The optional alloy 17"s might have an offset of +45.
Tirerack steel wheels:
2010 and 2006 Corolla:
http://www.tirerack.com/wheels/results. ... ModClar=LE" onclick="window.open(this.href);return false;
15x6  closeout  $48.00
Offset: 33mm Backspacing: 4.80" Bolt Pattern: 5-100
Rec. Tire Size:195/65-15
15x6  $56.00
Offset: 54mm Backspacing: 4.842" Bolt Pattern: 5-100
16x6.5  $62.00
Offset: 54mm Backspacing: 5.511" Bolt Pattern: 5-100
Rec. Tire Size:205/55-16
2010 and 2006 base Vibe:
http://www.tirerack.com/wheels/results. ... alve+Stems" onclick="window.open(this.href);return false;
16x6.5  $62.00
Looks like they are closing out the 33mm offset, and the range they are showing is between 33mm-54mm.  Do not know center bore.  I think I read somewhere on genvibe that center bore is 54.1mm, but should be verified.
				Posted: Tue Sep 24, 2013 10:00 am
				by Chiadog
"Important notes" from tirerack link above:
"Wheel covers will not work with this wheel."
				Posted: Tue Sep 24, 2013 10:53 am
				by 10vibe
Good catch!  They also raised the price fom $48 to $54.00 since last night.
