is this possible, Adding amp and subwoofer box
Posted: Thu Jul 31, 2003 10:34 am
by LawMaker
I have an 03 Abyss Base Vibe, with Moon and Tunes package. My girlfriends brother is getting rid of his box and amp (2 10" pinoeers and a 400 watt amp) all setup for $175 so I want to get it off him, but I really do not want to replace my stock stereo I like how it looks and sound in my car. Here is my question... Is there anyway to hook this box and amp up to my stock stereo without having to replace the deck? Please let me know Thanks.
Re: is this possible, Adding amp and subwoofer box (LawMaker)
Posted: Thu Jul 31, 2003 10:46 am
by msmyer
Nope....would be since though!
Posted: Thu Jul 31, 2003 11:30 am
by Jahntassa
Yes. BUT.I added my old subs to the NAV system. The amp either needs hi-level inputs..or you need to spend about $30 on a speaker-level to RCA converter to connect to the amp.Get an amp wiring kit to run the power, and you're set. You can add a sub to any car stereo, though it does take a little bit of creativity.I have a lightning Audio B2.350.1 which is a mono amplifier with hi-level inputs and a remote level control.
Posted: Thu Jul 31, 2003 11:14 pm
by PhiDelt
es it is possible but instead of running RCA's to your radio they tap into the sstem hrouh your speakers using a modulator. The modulator only costs about $10 or less usually. It can be done.
Re: is this possible, Adding amp and subwoofer box (PhiDelt)
Posted: Fri Aug 01, 2003 4:32 am
by Jahntassa
quote:es it is possible but instead of running RCA's to your radio they tap into the sstem hrouh your speakers using a modulator. The modulator only costs about $10 or less usually. It can be done.He wants to go the other way..hook up an amp, not get something into the stereo..
Re: is this possible, Adding amp and subwoofer box (Jahntassa)
Posted: Fri Aug 01, 2003 6:09 am
by Sub-Vibe-R
Both way are good. Using an RCA converter with adjustable gain or simply use the hight level input of you amp.I had a sub with the factory HU in one of my previous car. To feed the remote of the amp., I used the accessory 12V of the HU, a relay and a toggle switch (to be able to turn on/off the amp).
Re: is this possible, Adding amp and subwoofer box (Sub-Vibe-R)
Posted: Fri Aug 01, 2003 6:30 am
by LawMaker
I will have to try something, I will bring my car to the local accessories store and see what they do, my friend works there so maybe they will give me a good deal LoL
Posted: Fri Aug 01, 2003 3:50 pm
by wildvibe
I always switch out my radio when installing system.You will always get much better sound thru RCA outputs
