Just when you though removing the antenna would be easy....
Posted: Fri Aug 30, 2013 1:28 pm
Ok got my new stubby to install, and I upon removing the old one I see that it just continues to turn. I can feel a notch as im turning. Almost like something is slipping underneath the base that may be part of the female end of the antenna assembly.Any suggestions outside of removing the base ??? I was thinking of cutting the top of the base off, like 1/8" ( and glue it back on later) to access whats turning & grab it with a needle nose, so I can remove the antenna. Any ideas ? Im stumped
