2006-2011 Hyundai corrosion recall.
Posted: Tue Aug 27, 2013 8:53 am
by Chiadog
Re: 2006-2011 Hyundai corrosion recall.
Posted: Tue Aug 27, 2013 5:38 pm
by ColonelPanic
A detached rear control arm, says NHTSA, “may suddenly change the rear wheel alignment, affecting the handling of the vehicle, increasing the risk of a crash.
LOL, love the legalese. Just like an inadvertent air bag deployment on the Vibe/Matrix "may startle the driver" or whatever it was they said.
I like Hyundai but geez... They've been battling undercarriage corrosion for years and still haven't figured it out. The prior generation Sonata and Santa Fe were also recalled for some pretty nasty subframe rot up front. Brake light switches and cancer of the subframes, two things Hyundai can't seem to get under control.
Posted: Wed Aug 28, 2013 11:17 am
by DeClercq
You'd think they'd have figured this out by now. My '03 Santa Fe had the front subframe replaced under the recall. The rear trailing arms were inspected and didn't need replaced, they just drilled some holes in them and filled them with some waxy goop. I didn't have it much longer after that...
Posted: Fri Aug 30, 2013 8:13 am
by Caretaker
regarding "figuring it out," if Hyundai had such a problem with undercarriage rot, shouldn't this recall be for more than just two models?? What is so special/different about these two models?
Posted: Fri Aug 30, 2013 8:23 am
by Rayven01
Caretaker wrote:What is so special/different about these two models?
They happened to rot in places where it caused sufficient safety issues to force a recall. For every recall there's a ton more issues that you just have to live with or fix yourself because the NHTSA doesn't deem it a safety issue.
Posted: Fri Aug 30, 2013 11:13 am
by Chiadog
Caretaker wrote: if Hyundai had such a problem with undercarriage rot, shouldn't this recall be for more than just two models?? What is so special/different about these two models?
Good question! Does anyone here know if the 2012 and newer Elantra and Accent have the same flawed crossmember design as the Sonata and Azera?
Posted: Fri Aug 30, 2013 12:04 pm
by DeClercq
Posted: Fri Aug 30, 2013 12:15 pm
by Chiadog
HOLY FIAT, Batman, That is Scarry!
