Car tried to peel out while I was stopped
Posted: Sun Aug 25, 2013 1:22 pm
Hello! The check engine light came on and I turned around and drove home. I pulled into the parking garage and stopped as one of my neighbors walked up to my car to talk to me. I was stopped for about 20 seconds when the car tried to peel out. I shoved it from Drive to Neutral right away and the rpm's dropped to normal idle.
The next day I took it to the dealer. They are saying it's throwing codes P2121 and P2138 for an accelerator position sensor. The dealer is trying to argue that it isn't covered under the epa 8/80k warranty, but I don't think they've read that in a while since the neanderthal looking tech said "that only covers the catalytic converter". I have a call into GM warranty to see if they are going to fix an obvious safety issue.
On another note, doesn't the accelerator assembly bolt on with two bolts and a plug? Seems like the $300 labor quote is a little steep for that.
Anyone experience this issue? This sounds like the Toyota debacle and is completely unrelated to the size of the gas pedal or to floor mats. This is on a 2008 vibe w/60k.
