Help! Leaky sunroof...
Posted: Tue Aug 13, 2013 8:40 am
Hey all,
Looking for some advice on what appears to be a leaky sunroof. I have a base 2003 Vibe with 127K on it.
About 2-3 months ago I started to notice that each time there was a really, really intense torrential downpour of rain, or anytime I took it through a high-pressure car wash, there would be a ton of water that would kind of pool right where the "fuzzy" roof liner ends and the hard plastic "column" near the door begins -- sort of right there a bit up and to the left of where your face is when you're driving. The water would either drip straight down from there or actually flow down the plastic part and drip down somewhere more or less where the left footrest is.
As of last night it's been steadily raining (more or less normal to light volume) here in the NY metro area, and although there's no major drippage (as described above), when I got in the car this morning I noticed a little bit of moisture and a couple water drops kind of beading up and just waiting to drop near the "back" of the sunroof, on the inside (the side closest to the back of the car; the side that "opens".)
Any ideas/advice? Could this be a problem just with the "seal" of the sunroof or is some drainage tube (?) clogged? Could it be both?
