losing rpm's
Posted: Tue Aug 06, 2013 8:07 pm
by gingerbread78
I have owned a 2005 Pontiac vibe for 3 months now and two of those months have been nothing bit problems. I lose rpms while driving and the car will not go over 20 mph. I have replaced mad sensor,spark plugs, catalyc converter, and o2 sensors. Now says my fuel pump has low pressure. Is this my possible problem b4 I spend the money to fix it!
Re: losing rpm's
Posted: Wed Aug 07, 2013 10:49 am
by SeattleJeremy
Can you give us some more information about the car? What engine and transmission? How many miles on the OD? What is the code being reported by computer? Does the engine sound like it's stumbling or does it die when in gear?
The car loosing RPM's when going up a hill, and not being able to get up to speed are both symptoms of a failing fuel pump.
Re: losing rpm's
Posted: Wed Aug 07, 2013 3:30 pm
by Chiadog
I am fairly certain your car's symptoms are consistent with a failed fuel pump/filter. I am sure you must correct this problem before any further troubleshooting is possible. I don't see that you have any option but to replace the fuel pump. Vibe fuel pumps rarely go bad, therefore I would consider a used replacement from the junkyard - If I could save enough money. How much does a new fuel pump/filter cost? I understand it is a relatively easy task to replace, if you can work safely with an open gas container and the fumes without blowing yourself UP! Start with disconnecting the battery.
Re: losing rpm's
Posted: Wed Aug 07, 2013 10:59 pm
by triz
Could be a bat catalytic converter too. You'll have trouble getting up to speed and it will severely restrict your RPM's
I apologize I saw you had that replaced are you getting any codes and if so what are they if they are more than one.
P???
