Fuel Gauge odd readings
Posted: Mon Aug 05, 2013 9:14 am
				2003 Vibe AWD With a similar problem as viewtopic.php?t=30913" onclick="window.open(this.href);return false;
BACKGROUND: My son wanted a bright LED version of the 2005. He bought a used 2005 cluster to later find out it would not interface as the 2003 because of the addition of a separate plug. Fair enough. So, he connected the 2005 plug that fit to the 2003 "to make sure it worked" before returning/reselling.
THE PROBLEM: After reconnecting the original, PROBLEM FREE, 2003 cluster, the gas gauge is--I'm assuming--not working properly. The car had nearly a full tank of gas before the ingenious cluster swap attempt. Now after a handful of miles, the fuel gauge is displaying almost a quarter tank left. The car is running great.
Would unplugging the battery for a while reset anything?
Some help would be appreciated. Thanks.
Once the gauge shows near empty, I will fill up to see how many gallons it takes.)
