cai install - remove bumper?
Posted: Wed Jul 30, 2003 12:41 am
by drunkenmaxx
ok i got my CAI yesterday and will attempt to install it saturday. in the instructions, it says you have to remove the bumper to install it. that doesn't seem to make sense to me or my uncle. can anyone clarify if and why if i need to remove the bumper?
Re: cai install - remove bumper? (drunkenvibe)
Posted: Wed Jul 30, 2003 12:48 am
by Triton
You do not need to remove the bumper. You can, but it is not a neccessary. There are three scews under the bumper in front of the drivers side tire. If you remove those, you will be able to put the filter on from underneath with the battery tray removed. It will be a lot easier to do especially since you will have help. Good luck! Take pics after the install.
Re: cai install - remove bumper? (Triton GT)
Posted: Wed Jul 30, 2003 1:00 am
by Sub-Vibe-R
There's a link to the Ingen CAI install on a Base Vibe.http://forums.genvibe.com/zerothread?id=1281Not necessary to remove the whole bumper.
Posted: Wed Jul 30, 2003 8:53 pm
As Triton said, removing the bumper is nuts!Simply remove two screws and one push rivet directly under the left front fog light. Then remove the half dozen or so push rivets scattered in the wheel well of the left front wheel (it's easier to see them with a flashlight). Then the plastic cover will just fall out, and make it SO much easier to get in there!!!
Re: cai install - remove bumper? (silverawd26)
Posted: Fri Aug 01, 2003 12:11 am
by TRICKEDVIBEGT
dont remove the bumper only the 3screws then it will be cake from there and if you have help even better.
