MBZ's 2003 'Envy' Vibe
Posted: Tue Jul 23, 2013 2:35 pm
by mbz321
My original thread I started:
viewtopic.php?f=11&t=41281" onclick="window.open(this.href);return false;. Figured I'd move it over here as I make some improvements to my new car.
First real "mod": Adding AUX jack to factory radio. I used the "iSimple Tranzit" kit, which works as a wired-in FM modulator. I like the look of the factory radio and I didn't want to change it out, but still wanted to stream music from my phone.
Took me a while to do (hooked it up to the wrong wires at first..whoops), but now it works great! Added the AUX and power switch to the dash, although you can put them pretty much anywhere as the wires are very long. (It also comes with a wired-in USB plug to charge your phone, but I decided to leave that out).
Next: Added these stick on wind/rain deflectors...were very cheap on eBay and installed in minutes with very strong 3M Tape.
Next to come: black out logos, add newer Vibe badge to rear (possibly pulling off side emblems), shining up the gray plastic, etc.
Re: MBZ's 2003 'Envy' Vibe
Posted: Tue Jul 23, 2013 4:21 pm
by vibenvy
I'm envious of your Vibe
Posted: Tue Jul 23, 2013 6:11 pm
by Rayven01
Great job on the aux plug! First mod like that I've seen come out so clean.
Posted: Tue Jul 23, 2013 6:18 pm
by mbz321
Rayven01 wrote:Great job on the aux plug! First mod like that I've seen come out so clean.
The on-off switch is slightly off (eg. the hole is a hair bigger than it should have been)...but all I was using to make the hole was an undersized drill bit. Would have liked it better if I could have put it in the center console area somehow, but that would have required a lot of work..But thanks!
Posted: Wed Jul 24, 2013 12:37 pm
by Doug14
Nice work! I might have to look into this is iSimple Tranzit kit
Posted: Wed Jul 24, 2013 5:18 pm
by mbz321
Doug14 wrote:Nice work! I might have to look into this is iSimple Tranzit kit
Amazon has it pretty inexpensively
http://www.amazon.com/iSimple-IS32-Univ ... roduct_top.
Note that you will also need to order the GM/Delco antenna adapters along with it.
http://www.amazon.com/Scosche-Mda-Kb-Mi ... _acr_txt_2
Also note to check the wires carefully...the black (ground) and red (power) wires that come from the iSimple do NOT match up with the black and red wires on the radio harness (those colors go to the Vibe's speakers)...check for a wiring diagram for the Vibe/Delco radio to match the wires properly.
Posted: Sun Jul 28, 2013 10:32 am
by Nj2ga2013
where did u get it from
Posted: Sun Jul 28, 2013 4:10 pm
by mbz321
Nj2ga2013 wrote:where did u get it from
Amazon... use the links above
Posted: Sun Jul 28, 2013 4:16 pm
by mbz321
More 'touch up' work:
Shined up the plastic all the way around using this kit from Amazon
http://www.amazon.com/gp/product/B005C4 ... UTF8&psc=1" onclick="window.open(this.href);return false;
(It is supposed to last up to 12 months..unlike other stuff that seems to wash off. It's been about a week and is still looking good)
Blacked out the logos all the way around using Plasti-Dip. Wasn't as easy as the YouTube videos made it seem, and it isn't 100% perfect (it's easy to peel off more than you wanted to peel). I did not remove anything before 'dipping'..that probably would have made it easier. (Overspray on the car comes off instantly with Goo Gone or Bug & Tar remover).
I also removed the plastic over the radio screen as it was all scratched up for some reason and made it impossible to see in sunlight. Doesn't seem to be really necessary, but may cut a replacement from an old plastic container.
Posted: Mon Aug 05, 2013 4:53 pm
by mbz321
Alright..thanks to Kincaid for donating me his newer "Vibe" badges..I removed the old style wording from the back, Plasti-dipped the new ones, and put them in place. Looks much better! (Still unsure what to do with the side emblems).
Posted: Mon Aug 05, 2013 5:54 pm
by canadave
Looks very nice, good job
Quick question for the naive and uninitiated such as myself...how did you remove the existing lettering, and how'd you apply the new lettering?
Posted: Mon Aug 05, 2013 7:15 pm
by mbz321
canadave wrote:Looks very nice, good job
I have seen recommendations of people using dental floss to sort of "saw off" the badges. Didn't work for me, the floss simply broke..I just used a gentle pry tool to pry the letters off, then used Goo-Gone to take off any remaining adhesive that was on the car. You can still see a very, very faint outline of where the old lettering used to be (can't tell by my crappy cell phone camera), but it isn't real noticeable and will probably fade with time.
Posted: Wed Aug 07, 2013 4:39 pm
by vibenvy
mbz321 wrote:canadave wrote:Looks very nice, good job
Fishing line is much more durable and therefore works much better
To re-apply badges, just get some good double sided tape (i.e. 3M Super Strong Moulding Tape @ Walmart in the automotive section for ~$5.00) and cut it to fit the backside of the badges (it doesn't need to match exactly, there just needs to be enough to hold the badge in place), than re-apply the badge wherever you'd like
Posted: Mon Aug 12, 2013 3:36 pm
by mbz321
Just the Vibe chillin on Ocracoke Island, NC
Posted: Mon Aug 19, 2013 7:24 pm
by Kincaid
Hey neat I didn't know yours was Envy! Maybe my favorite early Vibe color. I like the blacked out badging.
Posted: Thu Sep 12, 2013 2:07 pm
by mbz321
Finally had time for the next 'simple' mod...adding a turn-off switch for the DRL/Auto headlights. Simple enough following these directions:
http://www.electrolund.com/2005/02/matrix-drl-mod/" onclick="window.open(this.href);return false;
The space is extremely tight...although a 'smaller' person like myself didn't have too much trouble.
I used this basic Scion rocker switch available here, which fits PERFECTLY. I didn't really want one with an LED, but if you do, you will need another wire for ground. (Since I didn't, I just used the two wires from an old extension cord I had lying around)
http://www.oznium.com/gsw-45" onclick="window.open(this.href);return false; (Note they also sell this through ebay but the price is slightly more!)
Posted: Thu Sep 12, 2013 2:12 pm
by 455SD
Car is looking very good! Gotta love Envys
