light in master window switch panel
Posted: Mon Jul 22, 2013 3:05 pm
by 07cdnvibe
I have installed lights into the master window switch on the drivers door, the lights also allow light to shine around the other switches in this panel, I only have the one pic but will post some when it gets darker and the lighted effect is easier seen.Image
here is a pic of the panel lit up
Re: light in master window switch panel
Posted: Tue Jul 23, 2013 4:04 am
by Doug14
nice! sweet mod!
Posted: Sat Aug 10, 2013 6:30 am
by 07cdnvibe
thanks,
Posted: Sat Aug 10, 2013 4:27 pm
by Derf
Did you source the power from within the door, or run a wire into the dash for power?
Posted: Sat Aug 10, 2013 5:17 pm
by 07cdnvibe
Right now I am using an ignition wire to the power windows but it is on all the time I will be running a wire from the headlight circuit for power very soon then it will only be on at night as I run my park lights all the time so that would be no different than using the wire I am now
